Pacific Alaska, California, Hawaii, Oregon and Washington
your best 60'
Old Jun 12, 2004 | 02:22 PM
Amit's Avatar
your best 60'
whats the best 60 footer you guys have pulled?
and how do you launch?
Old Jun 12, 2004 | 02:25 PM
Zedzag's Avatar
2.22
I launch spinning my tires
Old Jun 12, 2004 | 02:27 PM
sideways_Into_3rd's Avatar
1.78
5000 rpm on two stage rev limiter, pedal to the floor
dump clutch, hit 150 shot of nitrous
Old Jun 12, 2004 | 03:09 PM
NiteRider's Avatar
2.0 on street tires.
Old Jun 12, 2004 | 03:58 PM
sleepybu's Avatar
1.95 on little street tires
Old Jun 12, 2004 | 04:00 PM
Camaro ChriSS's Avatar
1.96 on F1's
2.05 on Nittos.
I need to work on the DR launch. Only done it at the track once and the pad was real slippery. Should like to get 1.8. I think Mission has a history of not-so-good launching. ??? Have to test this.
Old Jun 12, 2004 | 04:11 PM
Tw!tchb!tch's Avatar
2.094 on 285 35 18 sumitomos last year
Thats my best 60 and I never finished the run , was a 16.770 @ 68.3 mph
Mostly 2.4 - 2.6 . . . . all hail the banzai launch .
Old Jun 12, 2004 | 05:55 PM
Zedzag's Avatar
Originally posted by Camaro ChriSS
1.96 on F1's
2.05 on Nittos.
Not exactly true. I have BFG drag radials on my 81 and my worst 60' is 1.88 with my best being 1.79, thats with only a 3000 converter . I don't know much about the Nittos but i'll bet the BFG would hook you better. The nittos are better for handling. With your converter I bet I could rip a low 1.7 as the bfgs do not slip. The only reason I can't do better is that my converter is too small and I have no power.
Old Jun 12, 2004 | 07:40 PM
JD30thZ28's Avatar
1.7 on the dr's
1.8 on the street tires
On the street tires I feather it out of the hole.
On the dr's I load the TC to about 2500 and punch it
Old Jun 12, 2004 | 08:09 PM
Well, guys with my convertor and nittos often consider a 1.8 bad, and regularly turn 1.7s (or slightly lower). I should hope to do 1.8s. But like I said, I haven't hit MRP on a good day yet. SO maybe I should shut up and stop complaining!
Old Jun 12, 2004 | 10:20 PM
OneFlyn95z28's Avatar
My best was a 1.65 on E.T. Streets and 1.67 on BFG Drs
the 1.65 was actually a spinning run
Oh yeah 1.78 was best on Good Year GS-Cs
BTW all runs made with Yank TP3800 and 3.73s
Old Jun 12, 2004 | 11:15 PM
krazzycowgirl's Avatar
1.992 on street tires taking off from an Idol.
it was also my best ET to date with a 14.669 @ 93mph in a ALMOST stock car.
Old Jun 13, 2004 | 12:12 AM
JeffK95Z's Avatar
I"ve yet to cut a sub 2 second 60'... 2.08 or something was my best... But that was on DR's
I know when I finally get my car in racing shape again (or able to afford to fix it if it breaks ) I won't be able to launch for the life of me tho... last time at the track was in '01 in calgary
Old Jun 13, 2004 | 01:11 AM
94Zman's Avatar
In the Z a 1.98 on...... 225/60-16's, the black stang years ago was 1.75 @ 4000rpm
Old Jun 13, 2004 | 01:51 AM
richy rich's Avatar
My best is a 1.31 on ET Streets,tripping the 60ft beam's w the back tires.
