Video software geeks. help.
Ok I have a copy of Adobe Premier Pro. Also Nero CD burning software
I have made two videos that I want to copy to a disk for purposes of playing on TV.
I have saved the file as .avi's and when I play them on the computer for the most part the resolution is really good (one problem is that there is a section where the action stops and the sound continues. Then the action starts again but I miss about 20 sec of video).
However, when I tried to save them as a Super Video CD (which took about an hour to burn) the resolution on the CD, when played is useless. I know Nate taught me about compression but I cannot find the software that does compression.
So the question is, how to burn a video that as good a quality of the original on a CD. - Note, I have a DVD burner on the desktop but I do not have the software on the desktop at this point. I'm currently using a laptop for this project. Would a DVD be better?
VCDs use a compression standard called MPEG to store the video and audio not AVI. The quality of a very good VCD is about the same as a VHS tape based movie but VCD is usually a bit more blurry.
The quality of a SVCD is much better than a VCD, especially much more sharpen picture than a VCD because of the higher resolution. But the quality depends how many minutes you choose to store on a CD, less minutes/CD generally means higher quality.
I would recommend burning a DVD, the quality is always better and same with the sound. Much easyer to burn and not as many steps are involved.
Here is a website to give you all the info you need.
you im not sure, all the VCDs that i have burned were with a special program that does all the b1tch work for me.... but never really turned out very good. So i just started using a DVD burner.
the movie file "SHOULD" (not always) be an MPEG to be properly burned... there are AVI to MPEG converters out there too.
cmsmith
Sep 14, 2015 09:09 PM
mark0006
Sep 14, 2015 12:35 PM
