Pacific Alaska, California, Hawaii, Oregon and Washington
tranny mounts
Old Oct 31, 2003 | 12:53 PM
Amit's Avatar
tranny mounts
everytime i shift i can feel my tranny moving around on me.
can i get some polyeurothane mounts for this bad boy?
that will help allot right?
i called mopac and they told me to call some place in california.
also my shifter feels harsh notchy and it doesnt go into gear easily. what can i do to elimanate this problem?
i want nice smooth shifts dammit
Old Oct 31, 2003 | 01:09 PM
sideways_Into_3rd's Avatar
u can tell if ur mount is bad if : when ur in gear and u accelerate and ur shifter moves up , ie pushes up on ur hand .. then ur stock mount is broken ...
doesnt take much to break a rubber mount . i broke 3 of them in a week before i bought a poly mount ... tell mopac to shove their heads up their *** and see if it fits
talk to someone else ... call vancouver mopac and talk to james he'll get u one .. or just goto lordco or best buy...
Old Oct 31, 2003 | 01:17 PM
ianwells100's Avatar
whats involved in replacing the tranny mounts? i think mine might be crapped, as when i accelerate hard (oxymoron for my car, i know) my shifter moves up, physically, a bit... also, when i loose traction (from a stop), sometimes it hopes all over the place... kinda like its crazy (adam sandler: give me some candy)
Old Oct 31, 2003 | 01:22 PM
its very simple
u need to put ur car on jackstands (the front)
then put ur floor jack under the tranny tailshaft to support it .. drop the tranny cross brace (4 bolts, 5/8" ) then undo the stock mount from the cross brace and tranny, 3 more bolts, put the poly one on and bolt up the cross brace
be careful not to over tighten the mount/tranny bolts, ur tranny casing is aluminum and u can f*ck it up easy (dont ask me how i know)
Old Oct 31, 2003 | 02:12 PM
Amit's Avatar
thanks Payam..
who makes these poly mounts?
Old Oct 31, 2003 | 02:42 PM
JD30thZ28's Avatar
Energy Suspension makes them
Old Oct 31, 2003 | 05:30 PM
NiteRider's Avatar
Dude, I told you when you bought the car it's not going to be a cadilac. The ES tranny mount will just improve your ****s and take the clunky sounds away but add to vibrations.
Old Oct 31, 2003 | 06:58 PM
LT1Z28's Avatar
Have one if you want can have it for 30 bones
later
Mike
Old Oct 31, 2003 | 08:26 PM
93formula's Avatar
or just get a 1le mount.
Old Oct 31, 2003 | 11:13 PM
NiteRider's Avatar
Hes SS has every 1LE option. Anything SLP, 1LE that car has it, it's as GM moded as possible.
Old Oct 31, 2003 | 11:20 PM
93formula's Avatar
well then dumbass tell him to get another on then. gee sorry i dont know every option he has
Old Nov 1, 2003 | 02:04 AM
Amit's Avatar
LT1Z28..
is it new or has it been used?
either way, i'll take it.
what kind of tranny mount is it?
Armen- i called mopac and asked them about the ES tranny mounts.. they had no idea what i was talking about.
Old Nov 1, 2003 | 06:35 AM
blue 79 Z/28's Avatar
just weld the tranny to the car! it'll give you the most rigid mount as possible and give you 100% transfer of power without any torque loss through the flexing of mounts etc.
Old Nov 1, 2003 | 10:03 AM
LT1Z28's Avatar
It is used low kms
I believe it was a energy suspension poly mount
Old Nov 1, 2003 | 10:54 AM
97TA-WS6-Con's Avatar
I bought my ES mount from Mopac in Surrey *shrug*
