Pacific Alaska, California, Hawaii, Oregon and Washington
power seats
Old Aug 6, 2003 | 05:28 PM
talos's Avatar
power seats
who here can tell me what i can run my powerseats off of with out spending alot??? someone said i could run it off my lighter... but i dunno...
Old Aug 6, 2003 | 05:31 PM
sideways_Into_3rd's Avatar
spending a lot of what ? wire ?! DAMN UR CHEAP
i got some pennies i will donate u
dont run it off ur lighter ... u'll blow the fuse
find something beefier...
did u put them in yet ? take some pics
Old Aug 6, 2003 | 05:34 PM
JD30thZ28's Avatar
$5 roll of wire. Power to battery source, ground to ground. Seat will move
Old Aug 6, 2003 | 06:27 PM
talos's Avatar
im just figuring out how im going to get power to the seats... from the battery. i have a small stereo... maybe plug into that power cable??? or just go right into the battery? is there a good wire i should get? heat stuff?
Old Aug 6, 2003 | 06:28 PM
Erik's Avatar
Classic Tech Moderator
There are probably a few extra spots right out of your fuse box.
Old Aug 6, 2003 | 06:32 PM
talos's Avatar
ill see
Edit: payam naw there not in yet, i tryed but the bolts are a bitch to get out, and u saw the tools i have to use
Old Aug 6, 2003 | 07:49 PM
NiteRider's Avatar
No, that motor in the seat is pretty hefty and power hungry. You better run it straight to the battery with some nice think gauge wire. If you connect it to your deck or cig lighter it will probably blow it or the fuses, use thick wire or else the power wire will arc and ground it'self killing you.
Old Aug 6, 2003 | 10:52 PM
talos's Avatar
well let me be the first to say that 4th gen seats are not a direct bolt in... the stupid mounting brakets on the back of the seat DO NOT line up with the holes on the floor
Old Aug 6, 2003 | 11:33 PM
NiteRider's Avatar
They do bolt up man, you just need to move the seat back and forth, try the passenger one. The driver one you'll probably have to connect so you can move it into position to bolt up.
Bolts have to line up with holes. Got it?
Old Aug 6, 2003 | 11:44 PM
talos's Avatar
im doing the pass side first... the 2 rear mounting brakets don't line up!... i even messured my old seat and the new seats.... its wider on the seat... it would fit, if the right side bracket was turned around, but its rivited in.
Old Aug 7, 2003 | 12:10 AM
Philbowski's Avatar
I'm pretty sure you have to throw the seats onto your old tracks, and drill holes in the tracks to accomodate the seats.
Old Aug 7, 2003 | 12:22 AM
talos's Avatar
power seats bud... there staying on the tracks there on
Old Aug 7, 2003 | 12:42 AM
97TA-WS6-Con's Avatar
ROLL CALL TIME
whoops
Old Aug 7, 2003 | 10:12 AM
CoryM's Avatar
Nate, they are just seats. Held down by 4 bolts. If I remember right 2 of the 4 line up and the other 2 you have to make new holes for. Use the biggest washers or steel plate you can find so they dont rip out of the floor in a wreck (seats are a safety feature too). As for the power they draw a LOT of amps so you will want a direct hookup to battery (with fuse or fusible link in between).
And Shaun, you do know you can delete your own posts right?
Old Aug 7, 2003 | 02:26 PM
talos's Avatar
ya well it seems im going to have to get new holes drilled... and what not... but i sure as hell is not going to drill any facking holes in my car... and none of u guys eather.... no shop will touch it eather.... just waiting for a call from performance automotive.
EDIT: as for the power, ill be getting thick gauge wire to a terminal box with fuses, then to the battery.
