Paging Big Mike
Paging Big Mike
My drivers side o2 took a huge crap on me today, do you still have a hook up on the gm brand 02's ?? Its a 2002 and I think Id like to replace both fronts.
Dave
Dave
Re: Paging Big Mike
Mines urgent , car wont run. Complete flat line on the drivers side bank , all four drivers side plugs are black like ihave never seen before. Car shakes like a bitch and stinks like gas too
Im going to pull it and try to clean it . . . .if its as dark as the plugs it might not be able to see anything lol.
Re: Paging Big Mike
I will order some fro you tommorow twitch. I might just order them in for you you can go pick them up and pay etc. They will be at carter GM on lougheed and willingdon i will let you know when they got them
Later
Mike
Later
Mike
Re: Paging Big Mike
Hold off if you can I just cleaned mine up, pretty sure they were just so covered in crap from my previous vacuum leak . There was so much build up they look kinda fuzzy on the one side.
Ill drop the car off the stands and see how it is . About how much are these things through you ?? They wanted 130 bucks each at musalems . If I do 1 I think Ill have to do them both eh ?
Re: Paging Big Mike
Thats a great price.
I fired it back up and there bouncing around again on the scanner but not very crisply. I didnt have a chance to run it through the gears and see how it does. I switched the ****ed up o2's from the rich side to the lean side also and its not backfiring and missing anymore.
My pipes are so black with suit inside its crazy . . . . when the moisture poors out the tailpipes its more like sludge.
NewsBot
Aug 3, 2015 02:40 PM
Catmaigne
Jul 14, 2015 05:17 PM
