Opti re and re on wednesday - anyone wanna help?
Hi guys,
Mike S. came over and checked the car.... looks like the opti may be on wrong. I will be removing and reinstalling it tomorow (wednesday) evening - does anyone want to help? I have never done an opti before so I wouldn't mind some backup
yeah but Craig don't start the car the way it is now, I woulnd't advice it, I told you the opti is prolly on wrong before but maybe its a good thing you didn't do anything about it considering the motor is hard to turn.
Also, if the motor is turning really slow it won't start, remember it has to build compression & with 8.5:1 & really slow turning thats hard to do
a 45 minute job
Id help .. but im 3000 miles away tomorrow
good luck.. hope that ends ur nightmare...
um, dont start ur motor without the hub/balancer...
but try it out without the waterpump to make sure it runs and idles (idle it for 15-20 seconds)
also be careful when ur pulling and reinstalling the ur fancy 1 piece balancer ... make sure to rent a BALANCER PULLEY puller from canadian tire .. NOT a hub puller .. since u dont really have a hub no more... (they have 2 different pullers, and one wouldnt work for anothers purpose)
Matt: Mike and Eric did fairly extensive testing of the valvetrain etc etc. In addition the battery was tested and is a little weak as well.
The other thing is that there was a fairly serious backfire through the intake - and I mean serious smoke - so that HAS to be an ignition timing issue.
Even IF there MAY be problems with the short block, until the opti is looked at, cannot know for sure.
I already rented the balancer puller - its a 3 armed thing with big claws right? they look to reach out about 8 inches across.
OMG serious, I'll do it no probs
I'm not joking maybe even sooner LMK when.
go do craigs...
you will be times .. from the time you pick up the rench till the time you drop the rench.. the car MUST start
