Pacific Alaska, California, Hawaii, Oregon and Washington
Noisy Door Fix !!
Old Jul 3, 2004 | 05:30 PM
Tw!tchb!tch's Avatar
Noisy Door Fix !!
I always hated the noisy *** fbody doors when you shut them ( that metal thwacking around sound inside ) . I did a little diging around in there and found 99 % of the noise is from the slack in the rods for the lock and door handle . . . .
1. get some canopy tape ( one sided )
2. Pull Door panels
3. Carefully pull back vapor barrier
4. Snap the rods outa that black block and move the rod socks ( the little covers that let the door handle rod and lock rod move freely while inside that little block ) so there centered but most the slack is towards the latch side . Cut about 1.2" off the latch side of each ( a little less on the smaller one. ) but leave em on the rod and slide them down towards the latch outa the way for now .
5 Take canopy tape and lay it under the rods by the block to keep a very slight pressure againsed them ( under the socks ) Do a couple in the middle by the little " snap block " doey and a nice 1" by 1" peice on the inside of the door panel where the rod for the door handle first goes back in behind again ( closest to interior passengers door handle ) .
6. I found most the noise was in the hinge slack itself and not the actual rods smaking the inside of the door so I took 2 4" long peices and stacked them up. Stick them on the inside part of the door panel where the rods go behind ( closest to the latch this time ) . Once there on there good and you have decent pressure againsed the rods ( pushing towards the outside of the vehicle ) take the two sock peices you cut earlier and move them into position sheilding the rods from the friction/ pressure of the canopy tape. There should be enough pressure from the insulating tape to keep the little socks in place.
Done no more noise is like a lexus lol
Old Jul 3, 2004 | 05:34 PM
93formula's Avatar
were you just bored?? thats a lot of work, and added wieght for some noise
Old Jul 3, 2004 | 05:37 PM
John1975's Avatar
You need another knock sensor to go bad so you stay out of trouble.
Old Jul 3, 2004 | 05:39 PM
Its the little stuff that drives me nuts like hot chicks with ugly feet
Old Jul 3, 2004 | 05:45 PM
93formula's Avatar
lol, then your driving the wrong car remember the headlights RRRRRRRRRRRRRRRRRRRRRR
Old Jul 3, 2004 | 05:47 PM
John1975's Avatar
yes, nothing like the one eyed blinking transams
Old Jul 3, 2004 | 05:50 PM
93formula's Avatar
the f body isnt perfect but they haul ***.
Oh yeah
My headlight "bonk" noise fix
For anybody with a transam, the oem headlamps are designed to keep pushing past the stops. When theres a build up of current ( they have hit the stops ) they shut off. Not only does this cause stripping of the teflon internal gear but its ****ing noisy !!
1. Get some of those screws that have built in rubber stoppers ( holow style )
2. remove existing screw from new stops
3. Remove top bumper on each side of the car ( white teflon meterial )
4. Insert new beutiful soft bump stop
Done , no more " BANG " when the lights come up
Old Jul 3, 2004 | 05:52 PM
John1975's Avatar
The f-body doesn't seem that fast, not much diff than my car.
Old Jul 3, 2004 | 06:01 PM
93formula's Avatar
and how much did you pay for your car?
lets see you on the sea to sky or the hope to princeton
Old Jul 3, 2004 | 06:07 PM
John1975's Avatar
too much
and sure...............it is supposed to handle ok........0.9g stock on the skidpad I think.
Old Jul 3, 2004 | 06:10 PM
93formula's Avatar
the f body is the best bang for your buck you can get.
Old Jul 3, 2004 | 06:12 PM
John1975's Avatar
yep, it is. And I couldn't find one that I wanted for sale.
So I bought the car with the best bang for your buck when you add mods
Old Jul 3, 2004 | 06:13 PM
All our cars kick *** lets go race around and cause trouble for the old folk
Old Jul 3, 2004 | 09:38 PM
bunker's Avatar
Good to have someone like you on our board with some body shop experience knowing everything about doors etc... I never realized that the noise came from that, I always thought its something to do with the door hitting somewhere or rather & nothing could be done, good to hear, I never even would have bothered to fix this noise cuz its one of those messy jobs & gains no power, plus its something I just don't mind after a while LOL, I think everyone is like that with these cars, just grows to live with the many noises, with me if that was the only imperfection yeah I say try fixing it, but there is so much noise with these cars, only fix is an electric cut-out LOL.
