Pacific Alaska, California, Hawaii, Oregon and Washington
Need A New Tranny
Old Aug 30, 2005 | 11:39 PM
1quickgt's Avatar
Need A New Tranny
yup 94 trans am 62,000 k's went on me tonight what a pos im so upset..anyone that could advise please do..thanks again
Craig
Old Aug 30, 2005 | 11:48 PM
talos's Avatar
Re: Need A New Tranny
m6 conversion
Old Aug 31, 2005 | 10:02 AM
NorthernSS's Avatar
I had work done on my old Jimmy at a place in Surrey called Blackwell Distributors. They are on Scott Road at the bottom of 108, towards the skytrain station. They did really good work and stood by everything they did. If you need to go to a shop I recomend them.
Old Aug 31, 2005 | 01:28 PM
JD30thZ28's Avatar
What happened? What are the symptoms?
Old Aug 31, 2005 | 05:26 PM
93formula's Avatar
if you need a 4l60e i got a few kicking around
Old Aug 31, 2005 | 07:15 PM
1quickgt's Avatar
its weird it has a REALLY rough idle and only has a gear in reverse drive and the others are all screwed...i was looking at it last night wiht my old man there is a wire harness directly by my header that is a bit burnt...could this be a factor? cause when i scan the car for trouble codes my fans turn on thats all...any ideas??!!
Old Sep 1, 2005 | 12:44 AM
Drumhawk's Avatar
Sorry to hear it, I hope it's not the tranny.
Old Sep 1, 2005 | 11:29 AM
kcsoz20's Avatar
Thumbs up Re: Need A New Tranny
I have an FLP stage 4 vacuumn modulated for sale $1200 U$ if interested.
www.FLP2win.com click here for specs.
Johnny had showed some interest in it as he thought his trans was going but I have not heard from him
Johnny?! Ya there?!
Ken
Old Sep 1, 2005 | 02:02 PM
bunker's Avatar
There is only one wire that is close to the headers and thats the PCM ground I think but it's got a heat shield, did you check the fluid level etc...? somehow I doubt it's your tranny.
Old Sep 1, 2005 | 09:42 PM
Muskys SS's Avatar
Auto Trannys usually don't die over night. Check your fluid level. If good then I'd drop the tranny pan and see if the pick up or tranny filter came loose. It sounds like something inside may have loosened up.
Old Sep 2, 2005 | 02:11 AM
bunker's Avatar
Yeah, that tranny was leaking pretty bad, definitely check the fluid level.
Old Sep 2, 2005 | 08:55 AM
1quickgt's Avatar
first thing i did...the headers burnt the ground wires you were talking about, its right by the firall...pull hem away form the headers and the car had drive again for a min but the second i put it back on the ground...no drive
Old Sep 2, 2005 | 01:12 PM
bunker's Avatar
Yeah those wires have heat shielding on them and were pulled away, guess it went back to it's old spot and burnt, no big deal, just have to redo that wire.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
