Pacific Alaska, California, Hawaii, Oregon and Washington
Need help...Hesitation at high revs
Old Apr 27, 2004 | 06:09 PM
Woja's Avatar
i did a search on this topic but my problem is a little different the all the ones i could find. i also posted a message in the LT1 Tech forum, but after only a few hours my post is like 4 pages back
my car started to hesitate yesturday. if i boot it, it runs fine until about 4 thousand rpm then it hesitates and really just doesn't want to go any faster. but when i change gear, it runs fine again until the same rpm. it hesitates at all temps. tell me if you don't know what i'm talking about.
i had a similar problem with my old car and it turned out to be the ECU wiring. could this be the same problem? i don't even know where the ECU is.
Or could this have something to do with an airleak?
any help would be greatly appreciated
thanks, Mike
Old Apr 27, 2004 | 07:23 PM
93formula's Avatar
mine did that before and it was the opti, how old is yours, check your waterpump for leaks.
Old Apr 27, 2004 | 07:27 PM
Rybar's Avatar
Mine did that along time ago. It was a cracked plug. Check your plugs and wires.
Old Apr 27, 2004 | 07:41 PM
Draco's Avatar
check coil, plugs, and wires for high rpm issues... opti seems more prevalent with low rpm stumbles but it could still be the problem.
Old Apr 27, 2004 | 07:47 PM
Camaro ChriSS's Avatar
As has been said, check plugs and wires. Sounds like that to me.
Old Apr 27, 2004 | 10:52 PM
StreamlineZ28's Avatar
mine did that a while back. i could punch it till about 4000-4500 and then it would start to stumble really bad. mine was the throttle position sensor (TPS)
Old Apr 28, 2004 | 11:20 AM
Woja's Avatar
thanks for all the replys
i got quoted like $90 for labor to change the spark plugs, so i was like ahhh no. when i bought the car i had it checked and the gap in the plugs where to big. i havent looked that hard but so far i havent even seen where the spark plugs go
so i get the feeling that i want be able to change them. but i'll check if i can change them today. i was gonna change them soon anyway.
i did some searching and as Draco said a bad opti has more to do with low rpm hesitating.
are there any other ideas?
thanks again for all the replys
Old Apr 28, 2004 | 11:34 AM
Woja's Avatar
i was told that it also could be one of the following:
MAP sensor
vacuum leak in the intake mann
a clogged fuel filter or low fuel press
timing is getting retarded
the list of options are growing, what do u guys think about these?
Old Apr 28, 2004 | 01:02 PM
Zedzag's Avatar
When I bought my 95 it would do the exact same thing. I changed the plugs and it rocked! Remember the rule QEC: quick, easy, cheap. Those are the thimgs to check/diagnose first.
Old Apr 28, 2004 | 02:19 PM
BennyBoy's Avatar
Same here.
Old Apr 28, 2004 | 05:09 PM
97TA-WS6-Con's Avatar
Got a question for the experienced guys.
How long you think it takes to change plugs on a stock motor?
Old Apr 28, 2004 | 09:58 PM
JeffK95Z's Avatar
changing plugs, for those that have done it many times, i can't see it taking longer then an hour to 2 hours MAX
I'm sure guys on here can do it much faster
Old Apr 28, 2004 | 11:00 PM
Draco's Avatar
with the right tools and good fingers should take about 60-90 minutes
Old Apr 29, 2004 | 12:36 AM
Woja's Avatar
thanks again for the replys
looks like i'll change the plugs - or at least try.
not sure if i should just get some cheap ngk ones or some "high performance" plugs. is there much of a difference between power and durablilty?
Old Apr 29, 2004 | 10:51 AM
Draco's Avatar
I'd switch to NGK TR55 copper plugs gapped to .050. they are quite cheap and will support more HP since they are 1/2 heat range cooler then stock.
