Pacific Alaska, California, Hawaii, Oregon and Washington
My Tranny is DEAD:(
Old Jun 9, 2004 | 10:04 PM
  #16
oldschool's Avatar
Just got out from under the car.
I jacked it up and left the weight on the suspension to simulate driving conditions. I ran it through all 6 gears and gave it part throttle in each.
I "think" (pretty sure) the noise is comming from the rear-end. It was kind of a rattle. What is weird is that from what I could tell, everything was spinning smoothly. When I put the clutch in the sound would go away, but I figure that is only because the load is off the gears.
any ideas?
Better yet, anyone experienced going to be roaming the North Shore anytime soon and want to do me a huge favour by listening to it???
Andy
Old Jun 9, 2004 | 11:10 PM
  #17
TyphoonZR's Avatar
Hey, I'm in for a roam....... do you have the tools and axle stands etc, so that we can play for an hour or so??? Let me know.
Old Jun 9, 2004 | 11:42 PM
  #18
Draco's Avatar
any ideas?
Andy
Just a thought... you cant simlulate wheehop very easily with this method. The problem with wheelhop, acceleration, and the control arm angle I saw on your car is that as the wheels move up in the well, the rear end rotates up and forward around the mounting point of the control arm on the body. This rotation, which you cannot simulate easily with the rear end on jackstands, will push the Driveshaft further into the tranny.
good luck man, trannies are the most complicated mechanical system on the car and they scare me
Old Jun 10, 2004 | 01:40 AM
  #19
oldschool's Avatar
I am pretty sure it is the rear-end now Craig Either way it doesn't sound good.
Thanks Typhoon perhaps this weekend? I'll let ya know
Andy
Old Jun 10, 2004 | 03:03 AM
  #20
sideways_Into_3rd's Avatar
damn that would suck
wanna buy a reliable 12 bolt ?
Old Jun 17, 2004 | 11:59 AM
  #21
Hawk350's Avatar
Check your plugs and wires. If your spark plug wires are burnt, the cylinders will misfire, and you may not even know. This will cause this....because it happened to me this weekend. Shifter was violently vibrating in 6th. Changed plugs and problem solved.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
