Pacific Alaska, California, Hawaii, Oregon and Washington
Moser 12 Bolt Repairs
Old Feb 24, 2004 | 01:37 AM
Jason Dove's Avatar
Hey guys, I think my Moser 12 bolt is about to bite it. Looks like the pinion seal is leaking, the car is vibrating and it makes nasty noises.
Anyone know a 'good' place to take it to. I think my gears are still good, just the bearings/seals are shot.
Old Feb 24, 2004 | 01:51 AM
Rybar's Avatar
I took my Strange to Tyler at Rear-End specialties in Langley. Good, honest guy to deal with.
Unlike those losers at IWE.
Old Feb 24, 2004 | 01:53 AM
talos's Avatar
what type of work do they do? anything and everything?
Old Feb 24, 2004 | 06:45 PM
TyphoonZR's Avatar
Jason, my guess is that the guys who installed your gears did not put lock tight on the yoke nut! If you are a handy man, jack your car up, secure it, then see if you can move the rear end yoke forward and backward a bit, if so, you will have to tighten the nut with lock tight and it should also be checked for correct tention. All this should be a relatively cheap fix, like 50 bucks!
Old Feb 25, 2004 | 01:50 AM
Jason Dove's Avatar
K, I'll take a look. I planned on taking it to Mike's place and lifting it up to check. My apartment is really **** about jacking cars in the lot.
Moser built the rear, so I would have hoped they would have used lock-tight on it, but you never know.
Old Feb 25, 2004 | 10:19 AM
TyphoonZR's Avatar
Jason, let me put it in another way. Even if the installer had used lock tight, as hp goes up, and especially if you have a standard transmission, the bolts have a way of working themselves loose.
This happened to my son's car in which he had a t-56 and the installer said he had used lock tight. But as a driver goes on and then off the gas repeatedly, the bolts start their action and once in a while, it is a good thing to just check the big nut i the center of the rear end yoke, a 5 minute job to check it. If the car is on the hoist having an oil change, just go to the back, grab the drive shaft and try and work it back and forth, not left and right. If there is more than a 1/16 inch travel, you got problems.
Old Feb 25, 2004 | 02:02 PM
Mikey 97Z M6's Avatar
Some guys even go so far as to tack weld the nut to the pinion after the pinion depth has been set. Works much better than thread lock. Nothing will waste a pinion gear/bearing faster than having that nut come loose and applying some good power to it.
Mike
Old Feb 25, 2004 | 02:32 PM
95wagon's Avatar
You might want to consider a solid pinion spacer with shims and lose the crush sleeve.
Look at the right lower of the page on the following link.
Ratech
Old Feb 25, 2004 | 02:42 PM
Jason Dove's Avatar
Thanks wagon, I used to run the RaTech spacer with my 10 bolt. Good unit.
HarleyZ28
Oct 5, 2015 06:23 AM
ddr698
Jan 9, 2015 10:05 AM
Wicked
Aug 22, 2002 12:37 PM
kev93z28
Aug 19, 2002 12:48 AM
