Pacific Alaska, California, Hawaii, Oregon and Washington
It's Alive!!!
Old Jun 5, 2003 | 07:49 PM
Erik's Avatar
Classic Tech Moderator
Cool It's Alive!!!
Finally, my ZZ430 clone runs! I've only had it run for half a minute because I don't want to **** my neighbors off, and open headers in a poorly ventilated garage and a very rich exhaust makes it impossible to stay in the car for long
Saturday I'll push it out of the garage and spend 25 mins or so on the break-in
So, now that it's running, what should I do to get it roughly tuned for the break-in?
Old Jun 5, 2003 | 07:52 PM
NiteRider's Avatar
Yeah man, congratts, roll her out and start on those first few oil changes. Then hit up the synthetic, motor like that diserves nothing less.
Old Jun 5, 2003 | 07:53 PM
CoryM's Avatar
Glad to hear it man. What kind of carb or EFI you using? Also if your cooling system isnt as good as it could be set up a fan or two to blow into your rad when you break in the cam.
CoryM
Old Jun 5, 2003 | 08:17 PM
bunker's Avatar
DON"T LET HER IDLE, keep RPM high, nothing like starving the lifters & rings of oil make sure you're not running too rich either.
Old Jun 5, 2003 | 08:21 PM
Erik's Avatar
CoryM
Edelbrock 750 Carb.
MSD distributor, wires and ignition.
Headman Headers (couldn't afford Hookers )
With the exception of a starter, pretty much everything else was on the engine when I bought it (including the distributor )
thanks for the tip on the fan. I'll borrow a big one from work tomorrow
Old Jun 5, 2003 | 09:13 PM
sideways_Into_3rd's Avatar
bring her out cruisin
break in tomorrow .. then some road breakin on sat
Old Jun 5, 2003 | 09:42 PM
CoryM's Avatar
If the carb settings are still setup for the last V8 just leave them as-is for the cam break-in. At 2200-3000rpm you will be fine. Then after that start tuning it. I dont have much experience with the edelbrocks so not much help there.
Hope all goes very well
CoryM
Old Jun 5, 2003 | 10:52 PM
Erik's Avatar
The carb is brand new out of the box. The exhaust was so rich I couldn't take more than half a minute of it running
Cruising this weekend will be out of the question I don't have a complete exhaust system. As much as I like the sound, I'm sure most others don't.
Old Jun 6, 2003 | 12:42 AM
Jason Dove's Avatar
Can you still run your old headers on it, or did you have to buy new ones?
Old Jun 6, 2003 | 07:52 AM
Erik's Avatar
I needed new headers. The old ones were only 1 5/8", my new ones are 1 3/4"
C4m4roJoe
Jul 19, 2015 10:59 PM
madwolf
Aug 31, 2003 02:07 AM
Robert95z
May 30, 2003 06:00 AM
SVT Killer LV
May 28, 2003 04:10 AM
96ZRDR
Jan 27, 2003 10:25 AM
