Pacific Alaska, California, Hawaii, Oregon and Washington
Help...just bought 1.6rr's
Old Mar 24, 2003 | 12:23 AM
1994CamaroZ's Avatar
Question Help...just bought 1.6rr's
I just bought crane gold series 1.6 roller rockers......now do I need to change the valve springs? I have 70,000km on the odo. I have a stock cam too.
If I do need to change the valve springs(which i really don't want too) can I make out with the LT4 valve springs? How much are they from GM? Can you guys give me a part number?
Thanks guys
JIM
Old Mar 24, 2003 | 01:28 AM
oldschool's Avatar
Yes, you have to change the valve springs.
Get the comp cams "ovarian" (sp?) from Mopac for around $70. It's a single sping that uses the latest technology that results in it being better than most double springs. Plus they are WAY easier to put on.
good luck
Andy
Old Mar 24, 2003 | 10:53 AM
Draco's Avatar
Andy
I have heard of ovarian cysts before, but never ovarian valve springs....
are you planning on keeping the stock cam? If so you might be able to get away without changing springs - I can't remember the max lift that stock springs support. the LT4 springs would be a good choice though since they are single coil (thus easy to install) and cheap.
Old Mar 24, 2003 | 11:09 AM
JD30thZ28's Avatar
You will have to change the valve springs, the LT4 springs will work but if you plan to do a cam in the future it would be best to get some better valve springs now so you don't have to change them again because it isn't a fun job to do
Old Mar 24, 2003 | 12:24 PM
Oldschool with the stock retainers work with those springs?????????
Jim
Old Mar 24, 2003 | 12:40 PM
Pandamonkey's Avatar
I could look this up on LT1Tech but...........I would get varying results and it would be in US dollars.
How much is the RR and springs mod?
Is there any SOTP increase to be had?
jasonduaine
Apr 1, 2015 08:09 PM
grabbem88
Mar 25, 2015 12:09 PM
95chwagon
Feb 28, 2015 12:02 PM
94redform
Sep 8, 2002 03:27 AM
99TransAmWS6
Jul 26, 2002 03:18 PM
