Pacific Alaska, California, Hawaii, Oregon and Washington
gauging intrest
Old Oct 1, 2003 | 08:10 PM
93formula's Avatar
gauging intrest
since its taking so long to finish my project i may consider selling everything if theres enough intrest in everything:
accel DFI (before gen 7) has calmap program, fan control harness, everything is brand new never installed: 800 usd
NOS nitrous kit, has high flow valve, remote valve opener, bottle heater, bottle blanket, all lines, fuel/nitrous solenoids up to 175hp, purge, TNT nitrous dual nozzle spray plate, jacobs nitrous master mind controller(brand new never installed): 800 usd
vortech s trim, polished version, has everything youll need less then 5k miles: 2600 cdn
58mm bbk throttle body: 275 usd
LTCC, brand new never installed, no coils: 500 cdn
LT1 bare block: 220 usd
moroso cai, good filter, the remainder of my k&n cleaner: 180 cdn
march ud pullies, with belt: 80 usd
forged trw pistons .30 over, used: 200 usd
forged eagle connecting rods, brand new in box, good to 850 hp at 8000 rpm: 290 usd
scat one piece rear main seal, internally balanced, brand new in box, never installed: 175 usd
xe 224/236 nitrous/blower cam, brand new never installed: 350 cdn
fully cnc ported 93 lt1 intake: 200 usd
keep in mind im just checking to see if theres intrest at these prices.
Old Oct 1, 2003 | 09:27 PM
KrazyKamaro's Avatar
Has the bare block been touched? Is there anything wrong with it like scored cylinder walls? Is it a two or four bolt main?
Old Oct 1, 2003 | 09:42 PM
93formula's Avatar
nothing wrong, 2 bolt.
Old Oct 2, 2003 | 02:39 AM
Rybar's Avatar
Roy, what CR are the pistons?
Old Oct 2, 2003 | 02:50 AM
blue 79 Z/28's Avatar
dood, you got all the pieces to put the motor together, just build it and drop it in geez
Old Oct 2, 2003 | 10:00 AM
97TA-WS6-Con's Avatar
Interested in LTCC and TB at those prices.
Old Oct 2, 2003 | 01:21 PM
StreamlineZ28's Avatar
need more info on the crank and rods please. what lenthg on the rods, h beam or i beam, what is the stroke on the crank and what is it made of. has it been balanced for the setup you have already
Old Oct 2, 2003 | 09:09 PM
93formula's Avatar
rybar- that would depend on your cc size of the heads, let me know what cc size it is and ill get back to you.
the crank is the stock size, the rods are stock lenth, 5.7" it was for a 355. they are h beam, the cranks a scat 9000. internally ballanced, the rods are balanced from the factory, but not all balanced together yet.
Old Oct 2, 2003 | 11:28 PM
93formula's Avatar
well after matt armen came over today ive decided to plow onward and keep everything. ETA 2005
Old Oct 2, 2003 | 11:36 PM
dang Roy I know u wanted to sell me a bunch of that stuff!
Old Oct 2, 2003 | 11:39 PM
93formula's Avatar
did you my PM??? i can get you most of that stuff at those prices
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
