Battery Group Purchase
Who's interested in Optima 'Red Top' batteries? We need a minimum purchase of *6* to get the $118 (plus tax) price.
The red tops are the same weight (33lbs) and the same size as the stock GM battery, but they are far superior with no off-gassing and the ability to mount in any direction- even sideways or upside down. The price again, is $118 plus tax.
ps. The batteries mount the same way and have top and side terminals like the GM one.
So i need everyone to confirm with me this week, and we can set it to get them.
I'm in... Cash in hand, ready to go!
but can we confirm the exact battery?
As in, is it this one:
Volts - 12
AH - 44
Amps @ 32 F - 910
CCA @ 0 F - 720
Reserve Capacity - 90
Length 9 5/16"
Width 6 13/16"
Height 7 5/8"
Weight 31.7 lbs
Volts - 12
AH - 44
Amps @ 32 F - 910
CCA @ 0 F - 720
Length 9 5/16"
Width 6 13/16"
Height 7 5/8"
Weight 31.7 lbs
Based on the part number, the specs i listed are correct... As for the slight variation on weight, perhaps packaging is inculded or something... Minor difference all the same...
Whats the cost normally? I'm interesting in how much we're saving
thanks for setting this up!
jeff
jeff
Mine lasted 2 years, then it wouldn't hold a charge anymore. Mike's didn't last too long either. Basically (in my experience) if you ever drain it completely, it'll recharge back up, but drain while the car is off. In several day spans of non-driving (3-4) my car would be dead on it's own.
Not trying to scare you off though, it's a good battery until you drain it.
It seems to be fine now. I just pulled the f-body out of the garage to give it a warm up in the driveway after not starting it for weeks. I'm gonna hold off getting a new battery until I need one so count me out on the this purchase.
Ok, warrenty is now an issue with me
I just read Mike's comment in the other battery thread and i'm scared of the Red tops and their supposed? lack of warrenty...
Stealth, can you confirm if there is or isn't one?
Thanks!
jeff
also, i do think the Yellow tops are much better for drainage issues, or i think thats what i read on their site?
Thanks!
jeff
