Anyone in Oregon want to meet up and tell me what the hell's wrong with my clutch?
I just installed a brand new Spec stage 3 carbon and now it seems like my whole rear end is going to pop out. The flywheel has been resurfaced and I tightened all the bolts to spec using a star patteren. I need someone to tell me if this normal clutch chatter. I've posted on many forums and all say this teeth crunching chatter is normal. I just need someone with some experience with clutches to drive my car.
I've just installed the twin turbo with all the piping and FMIC but it kind of sucks when I take off from a red and it sounds like I have a loose truck bed attched
I live in Salem BTW
I live in Salem BTW
This is an RX7 BTW with an LT1. The gears are stock 410's.
The chatter is so bad, when I down shift to go into a turn it feels like the rear tires are hopping around. I just really need someone to test drive this, I know it's not normal and it's hard to try to explain yourself over the internet. It's just horrible!!
mine was pretty bad when she was new, even when I would down shift, if I didn't pop the clutch out real fast the rear would chatter, now I still get some chatter in reverse & if I'm half a sleep & want to take off up a hill on a hot day when the brain aint working
then there will be a bit there.
Again, when she was new it was quite a bit worse, mostly in reverse & if I'm trying move while turning from a stop.
Matt.
then there will be a bit there.Again, when she was new it was quite a bit worse, mostly in reverse & if I'm trying move while turning from a stop.
Matt.
Originally posted by LT1RX7
how long did it last? I'm on 100 miles and it has either gotten worst or it's the same
[New Jersey] Cure those winter blues with the NJFBOA!!!
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
