anyone interested in a full NX kit ?
anyone want a complete NX kit ?
comes with
10# bottle, solenoids, nozzle, lines
NX bottle heater (with thermostat)
purge kit
blow down tube
on bottle pressure gauge
bought this kit for my next car .. but i need the money to buy my next car first
comes with
purge kit
blow down tube
NX and NOS kits that use regular nozzles are pretty much universal for any car. The only differences lie in tying in the electronics, mounting positions for noids and such, jetting, and routing of lines.
Of course, you have to make sure you have supporting hardware - most importantly a good enough fuel system.
You can put together your own custom setup fairly easily once you know how a Nitrous sytem works, but its usually cheaper to start off with a used kit and making it work for your application.
actually the only thing different about hooking up a wet system is the way u get fuel from ur fuel rail ... i think in civics u have to cut a plastic fuel line and put a T in there .. our cars have a shrader valve u can put a -4 AN line to
I'm already running a Holley 190lph pump so I think I'm OK for volume at higher-than-average pressures. I actually picked up a brass T nitrous fitting from a past junkyard visit so I'm OK for that also.
LMK what you want for it also
If it's in my (ridiculously low) price range I'll take it
I badly want to run 13s... but even a small shot of nitrous (50ish) with the slicks I'm getting should put me in the 12s.
Jan 23, 2015 01:13 PM
Brandon Wittmer
Dec 8, 2014 07:53 PM
Dec 4, 2014 11:56 AM
