Pacific Alaska, California, Hawaii, Oregon and Washington
AFS wheels info.
Old May 24, 2003 | 02:54 PM
Icelander's Avatar
AFS wheels info.
Hey guy's.
What offset should I get for the 17=11 rears for my 93 Trans Am of the ZR1 style wheels from AFS??
Does the standard ZR1 offset rubb the inner fender in the back??
Thanks, Jon.
Old May 24, 2003 | 09:58 PM
OneFlyn95z28's Avatar
No one has any info here?
I think you need the ZR1 offset but I am not sure. I am pretty sure if you call them they will know
Old May 25, 2003 | 11:24 PM
Steve in Seattle's Avatar
The ZR1 offset is 36mm, the Grand Sport offset is 50mm. The Grand Sport rims sit "inside" the car a bit more, but you'll need to "massage" the inner wheel well more and with probably need to trim the side of the jounce-bumper.
The ZR1 offset sticks out a bit more, but in the Ponitacs this shouldn't be a large a problem as with the Chevy's since the Poncho's "hips" have ~1/4" more clearance on each side. If the 315's don't fit, you can always go smaller (11" rims will fit as small as 275's) which will help lateral stability a bit, or you can roll the fender lip a bit and move the bottom of the rear valence piece outwards an inch using a shim.
Do a search in the Appearance Section for ZR1's and you see some recent threads I've commented on.
I have a chromed set of authentic ZR1's, and 2 authentic silver front wheels from a '95 ZR1.
I have the front chrome set on my car right now, and the rear set may need to be machined out a bit. I'm told the rear rims's inner hub (from ZR1's not the reproductions though) need to be "clearanced" a bit to fit the rear axles of 4th gens.
Once I get the rear wheels mounted, I could swing by and show you what they look like on a '97 Trans Am. May take a few weeks to get to it though... I'm swapped at work (82 hours last week).
Old May 26, 2003 | 12:46 AM
Steve no need to pay for machine work. I have done 2-3 Dozen now Including the setts on both our cars and all our spares
Flint78
Jun 21, 2015 01:28 PM
jasonduaine
Jun 4, 2015 09:29 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:33 PM
94bird
Aug 23, 2002 07:40 PM
