Pacific Alaska, California, Hawaii, Oregon and Washington
383 Stroker Motor
Old Jun 19, 2006 | 03:39 PM
XCLR8N's Avatar
383 Stroker Motor
I have a 383 stroker in my garage that is not put together. All work was done by Ellis(TwoFast4Luv) and/or his engine builder Mike. I have pics of all the pieces. The only thing that is missing is cam, lifters, and injectors and a few other small parts.
(1) LT1 Block that has been splayed to 4-bolt main with Milidon Main Caps. It was heat sinked and checked. Block only needs decked and bored
(1) SCAT 9000 Series Crank Shaft, Part # 9-350-3750-6000-L still sealed in box. http://www.scatcrankshafts.com/
(1) Set of LE Stage 2 Custom Ported Heads, no flow numbers since they were never assembled.
(1) Set of Ferrara Valves for the LE heads. I want to say 2.02 and 1.60 on the valves but cant remember for the life of me.
(1) Set of [16] 1.6 Roller Rockers from Dyno-Flo. This is a Comp Cams Pro-Magnum RR knockoff. They are brand new in the box with only one set of retainer nuts opened for visual check. Part # RKSS-350B 1.6 www.dyno-flo.com
(1) Set of K-Motion Valve Springs, Part # K-800 http://store.summitracing.com/egnse...5, 400115 115
(1) Cloyes Timing Chain Set, Part # C-3092
(1) Set of [16] Comp Cams Titanium Retainers, Part # 731-16 http://www.powerandperformancenews....6&Category_Code
(1) Set of Perfect Circle Performance Rings, Part # 315-0033.030.
(2) Sets of King Main Bearings, Part #(s) MB557SI STD and CR 807SI STD http://www.kingbearings.com/
(1) Set of [8] Eagle "SIR" I-Beam Connecting Rods, Part # SIR6000BBLW. http://www.eaglerod.com/products/Ch...SBC rods.html
(1) Set of [8] Probe Industries Pistons, Part # 12337-030. http://www.probeindustries.com/Pist...ED/Chev_383.htm
I also have a small box with all the original stuff out of the motor when the clean up and prep work was done to it.
All of these products are brand new and never used. Some are opened for visual inspection only!
I have a zip file with 20-25 pics in it, so if requesting pics make sure your email provider can handle the file. Also can provide ring specs in a PDF file format.
Price $2500.00
Old Jun 19, 2006 | 07:57 PM
Pandamonkey's Avatar
Re: 383 Stroker Motor
Are you selling or just bragging?
Old Jun 19, 2006 | 08:08 PM
XCLR8N's Avatar
I am selling for $2500.00
I never realized that the last line did not show up on the post, Sorry everyone!
Old Jul 9, 2006 | 04:24 PM
XCLR8N's Avatar
I am selling this motor for $2,200.00 now. This reduced well below what is has been put into parts and labor, so far
Old Jul 10, 2006 | 08:09 PM
93formula's Avatar
with the right cam this would be a killer NA 400rwhp+ setup! good luck with the sale!
Old Jul 11, 2006 | 02:17 AM
OneFlyn95z28's Avatar
All parts are good and new in box. Just needs final Assembly and a few parts.
This combo was picked out to make over 500RWHP on juice.
Matt sold the LT1 and bought a LS1 so parts are no longer needed
Old Jul 11, 2006 | 01:43 PM
93formula's Avatar
http://cgi.ebay.com/ebaymotors/New-E...temZ8042501266
no offense ellis but id say 400+rwhp because the rods are only rated at 500fwhp.
http://cgi.ebay.com/ebaymotors/New-S...QQcmdZViewItem
heck even the crank is good to 500 fwhp.
Old Jul 13, 2006 | 09:24 AM
XCLR8N's Avatar
SOLD!!!!
Old Jul 13, 2006 | 12:59 PM
93formula's Avatar
someone got a good deal!
Old Jul 13, 2006 | 05:29 PM
XCLR8N's Avatar
Yeah, I sent it out to him yesterday
D1SC383LT4
Jan 1, 2016 01:56 PM
Rde Bandit
Mar 21, 2015 10:17 PM
maybe2fast
Mar 13, 2015 11:48 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
