New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
Engine knock with car in park, can't pull eng codes.
Old Aug 30, 2005 | 10:57 PM
joed's Avatar
Exclamation Engine knock with car in park, can't pull eng codes.
I also posted this in the regular message board.
I have a 94 T/A with the 5.7lt1 and cannot pull any codes using a jumper conected to a/b. The SES light lights up without the jumper, but if i install the jumper and turn the ignition on I don't get a code 12 and the rad fans come on instead. I'm having trouble with the engine pinging when you step on the gas with the car in park. It was worse before i changed out the dist, coil and ign module. If the car wasn't so fun to drive I probably would have junked it by now.
I'm trying to salvage a few rides with the car before summer is over.
Thanks in advance
joe
Old Aug 31, 2005 | 10:20 PM
Kataklysm's Avatar
Re: Engine knock with car in park, can't pull eng codes.
It is a knock or is it just detonation? What octane gas do you use? Do you have an EGR valve or did you remove it? Any mods done to the car?
Old Aug 31, 2005 | 11:44 PM
TimboTA's Avatar
Let's start with the easy ones: Have you refueled since the time you changed all those parts, or is it the same tank of fuel? How's the condition of your exhaust? I used to have this problem when I had a rotted out Flowmaster on my car. HTH.
Old Sep 1, 2005 | 12:21 PM
joed's Avatar
No mods and stock exhaust. I've let the tank go down and refueled with fresh 93 octane fuel. It's sounds like detonation and it gets worse once the engine is warmed. The engine also gets real bad above 4000RPM. I ordered a scan tool last knight so I can moniter engine while it starts messing up.
Joe
Old Sep 1, 2005 | 09:54 PM
Kataklysm's Avatar
Check out the EGR valve, usually it would be a rough idle if it was bad but with it not functioning it will cause detonation due to combustion chamber temps getting to high.
Old Sep 8, 2005 | 12:02 AM
Green97Cam30th's Avatar
does it feel like it just holds at or around 4000rpms? if so it sounds like a spun bearing. is it RPM driven? (The sound)
Old Sep 29, 2005 | 03:31 PM
joed's Avatar
Talking Re: Engine knock with car in park, can't pull eng codes.
No the car was nocking. Well after getting fustrated and getting no where decided to send to a local performance shop for repair. After they changed out the PCM ( at $450.00 ) the car was no closer to running . I decided I could replace parts and see if it worked cheaper than the repair shop. Ended up the dist cap was shorting out once the engine was warmed up. The cap was only 1 year old ( oredered a complete opticrap from Jason ), after this experience OEM is no better than aftermarket, just more expensive.
Glad to have the car running again and the wife off my back.
ro2207
Dec 4, 2014 06:18 PM
jayblev95
Dec 1, 2014 06:55 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
Lions3
Apr 11, 2003 10:55 AM
