New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
cracked head saga finally over!
Old Jun 9, 2004 | 12:37 PM
jgeorger's Avatar
At least I think so!! For those of you who care or remember I had the GTP-headed lt1 Ram-Air that make some good numbers on the dyno in 2002 but liked to sip the coolant. After a round of head gasket swaps AND a new engine (Golens, who missed the crack in #1 exhaust port even after I told them to pressure check the heads) - I am happy to say crack has been fixed (2 shops and 9 months later - the first place butchered it up a little and could fix it - the 2nd place fixed it and the butchering - very nice work). I put the head on this past weekend, pressurized the system and it held!
Drove the car around a little bit. I forgot what it's like to drive without smelling coolant at almost every stop. I will monitor the coolant level but am fairly confident problem solved.
Now I need to get another 850 break-in miles on my new motor. Would like to hit the dyno for a baseline before I get the supercharger. Same cam, same heads as before.
Old Jun 9, 2004 | 02:27 PM
Josh-'04 GTO's Avatar
How will a "repaired" cylinder head handle the cylinder pressures of a forced induction motor?
Old Jun 9, 2004 | 03:30 PM
RealQuick's Avatar
congrats!
Old Jun 9, 2004 | 05:26 PM
jgeorger's Avatar
I'm going to find out! Besides, the crack was in the exhaust port, not in the combustion chamber. My other choice was to buy new heads. And knowing what I know now I would get AFRs ($1800 ouch) or the new Trick Flow heads ($1300) if they ever ship a pair....
Old Jun 9, 2004 | 07:01 PM
bowtiepwr's Avatar
>hey don't forget the Edelbrock Performer LT1 Head
http://www.edelbrock.com/automotive/index.html
this what Summit Racing charges
part # EDL-61909 $519.95
Old Jun 9, 2004 | 07:34 PM
jgeorger's Avatar
Yeah at least those are available! I felt the intake port is too small for my application and the combustion chamber is the same as stock at 54cc which is a real dealbreaker for me now Those would be best suited for a mild to moderate NA 350 or a mild NA 383. The Trick Flow heads are designed specifically for nitrous and blower apps with 64cc chambers and a relatively large exhaust port.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Chris Anderson
Jan 27, 2015 08:30 AM
squarehead
Nov 21, 2014 08:02 PM
