ZEX KIT! what does everyone think about it?
Old Dec 23, 2002 | 12:00 AM
6spdz28's Avatar
thinking bout buying the the zex kit for an lt1 will spary the 100 shot. im new to nos so im just wondering i will also buy bottle heater, purge kit, and pressure gauge. anything else i should do to make it more safe
Old Dec 23, 2002 | 01:47 AM
stik6shift98's Avatar
its nitrous not nos.....nos is like zex its a company.....
id say nitrous express nx cuz im a huge fan
but on your lt1 id get NOS...and then u can say u have nos
just wonderin...where in il are u
Old Dec 23, 2002 | 05:08 AM
GhostZ's Avatar
Not being an a$$hole but I'd say do a search.
Your question has been answered numerous times and you should also find some good links on nitrous that will answer your question.
To touch up briefly....yes, buy all the safety equipment you can, colder plugs, ignition for timing, NX is better, wet > dry, your bottom end will handle it and you will probably gain around a full second on a 100 shot.
Old Dec 23, 2002 | 11:13 AM
Loadre's Avatar
LOL @ GhostZ for answering his next 5 questions
Old Dec 23, 2002 | 09:03 PM
stik6shift00's Avatar
i heard its ok, but i would get TNT or NX, but thats just me
Old Dec 23, 2002 | 09:48 PM
nx nx nx nx
Old Dec 23, 2002 | 11:11 PM
Flyin t/a's Avatar
It's probably one of the better dry kits out there but you'll also need to run a better(not nesacarily bigger)injector. The increased fuel pressure will sieze up your stock injectors after a little while. Also zex only goes to 125 which sucks unless your afraid to run a 150 . I'd go NX they seem to be a good kit plus you'll save on injectors since it's wet. For the warmer defiently get an NX, it's cycling is determined by the bottle pressure while both NOS and ZEX use thermostats which are less accurate in maintaining specific bottle pressure. You'll also want an ignitiion with adjustable retard if your gonna go bigger than a 100 shot and a better fuel pump for more than a 100.
Good luck
Old Dec 23, 2002 | 11:29 PM
6spdz28's Avatar
hey everyone thanks fro all the replies i wasnt gunna get the dry kit i was gunna get the wet kit. and i have been reading up NX and TNT and i think if decided to go wtih TNT both are good systems but i like the plate system and it comes with blow down tube and pressure gauge so i tink i will get that one.
Old Dec 25, 2002 | 11:38 AM
NXz28's Avatar
nx nx nx nx
i'd go with a brand name that has been around for a while and you can trust.....for example NX
Old Dec 25, 2002 | 04:03 PM
TheZ's Avatar
nx look at my speed trap
Old Dec 27, 2002 | 06:53 AM
my96z's Avatar
If you want dry go Venom VCN-1000.
Old Dec 28, 2002 | 08:55 PM
Joe Brodman's Avatar
GP Moderator
That's what we all want.....a dry kit that decides the a/f ratio based off of readings of the stock, narrow band O2 sensors that were never meant to give accurate readings at WOT. That's about the last sensor in my car I'd trust to keep my motor in one piece! And the Venom system costs a fortune too!
Old Dec 29, 2002 | 12:58 PM
my96z's Avatar
I have not had any problems yet with the Venom. I have never heard of anyone blowing their motor with a Venom system. Not saying that it never happened but I have never heard of it. If anything is wrong it will shut the N2O off. I have missed shifts, hit the rev-limiter and it shuts the N2O off. I didnt buy any other saftey features for it either, dont need them with this one. Pretty safe if you ask me, so it must be doing somthing right.
Venom is cheaper than most people think. I only paid $600 for mine. The VCN-2000 is the exspensive one but has more features. I am one happy customer.
lt1xondeck
Mar 18, 2016 07:22 PM
karpetcm
Aug 14, 2015 03:02 PM
RX Speed Works
Jul 24, 2015 02:25 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
