Wiring the MSD digi-window switch.
Old Jul 6, 2007 | 07:56 PM
xdamagedx's Avatar
Alright, just about everything else is wired in but I don't know where to put the window switch. I put the FPSS between #9 and ground on this schematic (page 15): http://www.edelbrock.com/automotive_...7000/70001.pdf
I have the ground, tach, and power wires connected on the W/S, but I need to know what to do with the gray and yellow wires.
http://www.msdignition.com/pdf/8969_frm25515.pdf
Where is a good spot to have the W/S?
Old Jul 9, 2007 | 09:37 AM
Ray@NitroDaves's Avatar
the FPSS should be inline between the ground side of the relay and the yellow wire off the MSD, the gray wire will not be used....the gray wire is a 12 volt control wire...the yellow wire is a ground control.
the FPSS was not designed to carry the full amp load that the solenoids will pull
Old Jul 9, 2007 | 01:13 PM
xdamagedx's Avatar
cool, thanks a million
mr28
Apr 20, 2016 05:44 PM
detroit1994z28
Apr 19, 2015 08:11 PM
thenewkid
Apr 12, 2015 07:42 PM
mr28
Nov 23, 2014 11:11 AM
