Window switch needed with TPS?
Old Oct 19, 2004 | 05:49 PM
IdiotwithZ28's Avatar
Do I need to use a window switch if my nitrous is activated only at WOT with a TPS? I guess if I did use it, it would mainly be to shut the nitrous off above say 5500 rpm or so, but is it really necessary? Also, what about using some kind of retard control that activates only with nitrous? I've seen these little dials that turn on and off with nitrous flow and they can retard timing by as much as 10 degrees. Anybody here used one of these?
Old Oct 19, 2004 | 06:58 PM
MarkyMark's Avatar
Re: Window switch needed with TPS?
You will still need it for your lower rpm's so you can make it turn on at 3000 rpm and then shut off at around 5900 rpm. Wot switch will just make sure your at full throttle before the nitrous will activate.
Old Oct 20, 2004 | 01:26 PM
dirtybird96's Avatar
I use a manual switch instead of a window switch, and I know a couple of other people that do too. I usually spray when I know I have traction and let off at about 5500 right before it shifts. If you plan on bracket racing you should use a window switch so your times are more consistent.
Old Oct 20, 2004 | 07:24 PM
izzyz28's Avatar
I would definately incorporate a window switch and some means of retarding the timing into your system. I believe that the cheapest, safest, and easiest way to do this is to install an ignition box. Myself and many others on this board use the Mallory 685. I picked mine up for about $220 and it works great. If you go this route definately get the adaptor harness, as it makes installation a breeze. The 685 is a digital box that is very easy to program. It has two RPM limits, one for max RPM, and the second which is button activated for launching. You can program it to retard the timing when the nitrous system is in use, and of course it has the window switch along with some other features. Better to be safe than hear the dreaded POP!
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
edman
Jan 22, 2015 02:45 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
