Is a window switch necessary with an auto trans?
The transmission should keep it from over revving. And I can roll into the throttle to bring the rpms up before I floor it and activate the wot switch.
I don't have one, but I'm crazy like that. If the drive shaft breaks you can swing the RPMs way up quick and the computer will cut the fuel, however the N2O is still flowing and needs something to burn so it burns pistons. Leaning out on nitrous is bad news. I plan on getting one with my new kit.
biggest reason for a window switch with an auto is to make a stock trans live. spraying through shifts will kill a stocker or cheap rebuilt tranny with heat in a hurry. Most use the switch to shut the nitrous off right before the shift rpm.
if you are confident in your builder,go ahead and spray through shifts,i did for 2 years with a built trans from a member here. trans would of gone longer but i snapped the output shaft.
Re: Is a window switch necessary with an auto trans?
Dave
I was thinking instead of a wot switch I should have a push button on the console, then I could let off when I wanted. I see the msd window switch is only $76. I didnt wanna pay $200 for a nos brand one.
just get the window switch and have fun. we arent trying to scare anyone,just show the facts. a lot of guys use the msd switch.
window switch and a wot switch is the better combo,with a handheld button you risk spraying at too low of an rpm and causing engine damage.
What about the Jacob's Nitrous Mastermind? Doesn't this also have the same option as the MSD to turn on/off the nitrous at set RPM's plus I will be able to control how much the nitrous sprays in each gear I believe. And then use a relay so that I can hook the nitrous up through the TPS sensor. Just have to make the solenoids read 4volts at WOT I believe.
You guys are scaring me. Do you think a 100 shot is safe on a car with 135k? Or should I forget about it? I have a second car and eventually replacing a tranny wouldnt be that big of a deal.
