Why not spray below 3000?
Short answer is ...you generate too much cylinder pressure at lower rpms when you spray...tends to break and bend things.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Greg
95 Z28 conv M6
NX 150 progressive,
example (true story)
had a guy with a 289 I built, was spraying a 75 shot, and had the button on his shifter. One night, him and his buddy are doing test and tune, and while he is turning around on the road (at idle, maybe a little above) his finger taps the button. It coughs once, then runs real rough, so he takes it home and calls me. The next day we pull off the valve cover and find two broken rocker studs, and 4 bent pushrods. Luckily that is all he hurt, and he added a hi/lo rpm switch that weekend. Cylinder pressure is a wonderful thing!
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
