Where did you mount your bottle
Just looking to see some unique places where people have mounted their bottles. I thought mine was pretty unique seeing as how I've never seen anyone mount it there. Of course most people still have their a/c too. Post pics if you have them
Bottle pics
Bottle pics
Has anyone tried mounting the bottle in the space on the drivers side of the trunk, next to the T-top compartment? I would think that would be a prime spot for a sneaky bottle placement, and then carpet over the top of it. I just dont know if you can get the proper angle under there.
Hey man, see you are from Jville. You have any Camaro clubs there? I should ride out there one day.
Anyway the bottle should be mounted verticle with the pick up tube pointed towards the rear of the car. A 45* angle will work too. As long as you don't get stupid with the placement, you should be fine. Just remember when accelarating contents of the bottle will go to the back.
Re: Where did you mount your bottle
Bottle pics
Bottle pics
Did you run a vent tube outside?PS-I mounted my bottle in the hatchback well (no t-tops). It was the easy way out!
I had some either -8 or -10an (not sure which) hose that I snagged from work so I tied the 3 pieces of hose together with fittings and ran it along the pasenger seat and drilled a hole under the spare tire and ran a feed through to it and used it as a blowdown tube; or hose in my case.
spare tire well, cover it up can't even tell I have a bottle.
http://www.eden.rutgers.edu/~bhawalka/ccbottle.JPG
