Where can i find this set up
Old Jun 3, 2007 | 07:30 AM
MyNameIsMud's Avatar
Wet Kit
10 Pound Bottle
75 To 100 Shot
Arming Switch
Window Switch
Fuel Pressure Safety Switch
Bottle Heater
Purge Kit
Mallory 685 Box
Im in the middle of buying a house so im short on time to look for alllll these things i figured maybe one of you might have something similar. I drive a 91 z28 camaro. Thanks alot!!
Old Jun 3, 2007 | 09:23 AM
Boosted_Z28's Avatar
I would contact these guys: www.nitrousoutlet.com/
They are a supporting vendor on this site and they are a great bunch of guys to deal with!!!
Old Jun 3, 2007 | 11:53 AM
2000GTP's Avatar
Yes, great company to deal with. Also, if you buy the Mallory 685 box, you won't need a window switch as the Mallory unit comes with one as a built-in feature.
Old Jun 3, 2007 | 05:57 PM
sweeeeet what does all this run roughly?? also i drive a 91 z28 camaro a few bolt ons so on... but should i run a 75 shot or 100 this is my daily driver that i take to the track and street race with here and there.. thanks
Old Jun 3, 2007 | 06:49 PM
2000GTP's Avatar
My nitrous setup, which is similar to what you are asking about, ran around a grand total of 1500.00
Old Jun 3, 2007 | 08:37 PM
couple more things... can my stock engine handle 100 shot? or is it safer to just run a 75? alos whats up with the dual nozzle?
Old Jun 4, 2007 | 04:52 AM
Juiced91Z's Avatar
You'll be fine on 100 shot for sure, when mine was stock i put 150 through it and it loved it, it was only a 305 too! Dual nozzle, i dont think there is really any gain to be made there other than being able to spray more than a single nozzle can flow (which i believe is around 175-200) and for that matter you would be in direct port territory IMO. I also agree with Nitrous Outlet, top notch stuff and prices and customer service is the best to any company i've ever dealt with (car OR other related). Harris Speed works and Dyno Tune are a few other good ones as well. with everything you are looking to get, you could get it all for around $1000 brand new and cheaper is you get used stuff. You might also want to look into some plugs as well, some NGK TR6 plugs seem to be the most common/popular ones, or the autolite 103's. You should also be ok with the stock timing on 100 shot as well. Make sure you're Fuel pump is workin good, might want a new one or a hotwire kit for that. Thats about all you'll need, good luck with nitrous..its addictive!
Old Jun 4, 2007 | 09:12 AM
Ray@NitroDaves's Avatar
Thanks for all the kind words guys.....
PM Sent
Old Jun 4, 2007 | 10:25 AM
2000GTP's Avatar
The dual nozzle kit has a advantage when it comes to spraying bigger shots, but for what you have planned, a single nozzle will work fine.
Old Jun 4, 2007 | 12:54 PM
bkpliskin's Avatar
hey guys....quick question concerning my plans for nitrous as well
I've got a 97 Z28 A4 with a shift kit, CAI and a little exhaust mod....I plan on throwing some 3.73's on and a 100 shot on also. What kind of performance can I expect to see with all of this? If you can, could you give me a comparison of what kind of cars I'll be able to keep up with and/or beat with this combination.
Old Jun 4, 2007 | 01:31 PM
69z-28's Avatar
Nitrous Outlet is the place to go. i also have to recomend Harris Speed Works and Dynotune. These are some of my favorite companies in the entire automotive industry. Nitrous Outlet's customer service is unmatchable by most places and everything ive bought from them has worked great.
i agree 100% on the Mallory box, makes things really nice and easy.
i spent about 1200 for everything, got some deals here and there and i have everything you listed.
I highly recommend the Nitrous Outlet heated bottle bracket
Old Jun 4, 2007 | 02:01 PM
2000GTP's Avatar
With good traction, the nitrous might put you somewhere in the mid to upper 12s.
Old Jun 5, 2007 | 03:16 AM
Juiced91Z's Avatar
seems about right, depending on traction and how strong of a runner youre car is, i could see low 12's.
Old Jun 5, 2007 | 07:50 PM
so if i get a mallory 685 that will not only act as my ignition correct i can set my window switch and retard timing??
Old Jun 5, 2007 | 07:53 PM
and to have these features which mallory should i get some are pretty basic some are pretty crazy i would like to not go over board but im not budget either i want to safely have this set up
