Where can I find a 58mm TB Nitrous Plate?
Old May 8, 2005 | 04:48 PM
camz383's Avatar
Right now I have a 52mm Nitrous works TB plate, well ive been trying to bore it out but im not getting anywhere so Id rather just buy a 58mm plate...
Ive checked on barry grants website and cant tell what they are selling, and tech is closed. Does anyone know where I can find one at?
Or should I just go with a nozzle system? Not sure which is better...
Old May 14, 2005 | 08:53 AM
onefastgta's Avatar
Re: Where can I find a 58mm TB Nitrous Plate?
NOS sells one, but it ain't cheap, around $260 bucks, try to find one on ebay or the classifieds, they pop up every once in a while for half the price of new.
Old May 14, 2005 | 12:17 PM
U Can't Z Me's Avatar
TNT's is 58mm
Old May 16, 2005 | 10:09 PM
taguy001's Avatar
I used to run nitrous works, the plate they give you is garbage, doesn't atomize real well. I ended up switching to a single fogger after doing research, people picked up .2-.3 tenths by just swapping over to a fogger.
Old May 18, 2005 | 09:44 AM
Nitro Dave's Avatar
Im personaly not a fan of the plates behind the throttle body.Expecialy not nozzles behind the throttle body.
The problem is that the front runners are two close.I feel that it will not have time to attomize properly into the air stream.
Dave
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
