whats involved in installing a fogger kit on a s.b.c. 350???
Old Dec 18, 2005 | 05:40 PM
dnchevyman's Avatar
i was thinking about spending the extra 450 and getting a fogger kit instead of a plate kit. what is diferent about installing the fogger kit from a plate kit? i know you have to tap the manifold for the nozzles, is there anything else different? also, i was thinking about doing a 2 stage, how much more am i looking at spending? thanks guys
Old Dec 19, 2005 | 10:28 AM
NXRicky's Avatar
Re: whats involved in installing a fogger kit on a s.b.c. 350???
Nozzle kit will take alot more time to install then a plate will.. Drilling tapping a manifold installing the nozzle to an angle to clear valve cover and carb, linkage.. Just more time..
The positive side of things if you can go high hp will more tunability,,, you can adjust between cylinders if need be..
Ricky
Old Dec 19, 2005 | 07:22 PM
Nitro Dave's Avatar
Adding to what was said above you may also look into a progressive controller to simplify things instead of doing a dual stage.
Dave
Old Dec 20, 2005 | 03:32 AM
dnchevyman's Avatar
I recall, dont know exactly what, but people were having problems with progressive controllers?
Old Dec 20, 2005 | 09:37 AM
Nitro Dave's Avatar
That may be true for some of the earlier controllers that were on the market.There are still some I would not run.However there are some on the market now that I have been happy with and use myself.
Dave
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
