Whats the biggest shot on LT1?
Old Nov 23, 2002 | 10:40 PM
96Z28SS's Avatar
Is there a limit to what amount of NOS an lti can take due to the restrictions of intake and heads and opti-spark?
Concidering the bottom end was built strong. How much would be the limit? 400hp 600hp shot?
1000hp and 1000ft/lbs?
Rob
Old Nov 24, 2002 | 02:58 PM
RacinLT1's Avatar
If the bottom end is built right.......biggest concern would be ignition.
But i would think gby the time you are ready to spray more than 300-400 you wont be relying on the optispark much anyway.
I have seen a few cars go with a 300 shot while keeping the opti,but the msd/mallory/etc box takes care of the high voltage
Old Nov 25, 2002 | 10:52 PM
StevenPud's Avatar
i was using a 400 shot last year on a fully built bottom end, ported heads, lt4 hotcam, with the compression lowered to 9.2:1. i ran an msd 6a and timing retard but used the stock coil and opti. had no problems. i'll probably step up to a 450 or 500 next year.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
