What TPS wire for activating nitrous?
Old Dec 15, 2006 | 05:25 PM
EkS's Avatar
EkS
Hey guys, what wire on the TPS carries the voltage signal on a '94 LT1? I want to use the TPS instead of a WOT switch to activate my nitrous.
Anyone know?
Old Dec 15, 2006 | 09:30 PM
Ray@NitroDaves's Avatar
you will need to hook it to the rising voltage wire....not sure on the exact color but with a multimeter it will be the wire that increases from ~0-~5 volts as the throttle is opened
Old Dec 15, 2006 | 10:02 PM
1SlowFormula's Avatar
Blue wire per Fred http://64.65.63.61/forums/showpost.p...39&postcount=2
Old Dec 16, 2006 | 12:25 AM
EkS's Avatar
EkS
Yes, the blue wire is right. I had to do some digging, but finally found my answer. Thanks!
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
