what plugs?
Depends how much NOS are you going to run?How much compression does the engine have?Will the car be drove on the street alot?Are you running a MSD ignition?What plug are you running right now.You may be able to run the plug you are useing right now depending on the factors above.Please give more info. Thanks Mark
your gonna most likey need a colder plug than NGK TR-6. Do they make a 7? I think I am running AC R42LTS. I can't remember but I think thats it. It is 2 heat ranges colder than stock. A tr-6 plug is only a half a range colder that a tr-55. There r a lot of factors to use when deciding like an early post stated. Alan
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
