What piston
Im working on building a 383 nitrous motor with a 300 shot, I have been looking at je pistons but there is so many of them to choose, from, I want about a 12:1, the stock heads will be port n polished. Any suggestions on which je piston to choose? Do you guys think I should go aftermarket heads? Suggestions for that would be fine also.
Presuming your motor has the following specs:
4.030" bore 3.750" stroke in order to arrive at 383ci, there is only one JE nitrous piston to choose from in the catalog I'm looking at. JE Part # 232509 If you use the above bore and stroke, the above mentioned JE piston, which has a 3cc dome, a .020" deck height, a Felpro 1087 head gasket which is .039" (compressed height) and a stock LT-1 cylinder head (54cc), this will give you a compression ratio of 12.3 to 1. You will have to cc your cylinder heads to measure their actual volume as a lot of people found their heads to actually be closer to 58cc which would drop your compression to 11.7 to 1. This is presuming the deck height is .020" which is somewhat standard. This can be lowered to zero if need be and woulsd obviously raise the compression accordingly. Additionally, you can choose a thicker or thinner head gasket to raise or lower the compression as well. Note:The piston mentioned above requires a 6.00" rod. Hope this helps some. |
Originally Posted by Boosted_Z28
(Post 5107713)
Every 383 stroker piston can use a 5.7 rod. When u start going with a bigger stroke then 6.0 rods come into play. U will be fine as long as the piston is a stroker piston and JE is definately a great brand along with Ross for nitrous combinations, and I would go with a flat top from either one. For heads its your choice if u want to go with aluminum or iron depending on how much you are trying to spend. For aluminum I would go with 215-220cc dart pro1's or victor jr.'s. For iron heads i would go with Dart's 220-230cc platinum iron eagle heads.
Originally Posted by rallysport92
(Post 5108095)
Its really your choice I would use some nice 5.7 rods
You stated in your original post that you were building a 383, porting & polishing the stock heads and using a 300 HP nitrous kit...With this in mind, if you want to use a quality piston, like a JE that you mentioned. Unless yuo custom order a set from JE, there is only one choice from this company. JE only makes one "nirtous" piston and it requires a 6.00" rod. You may find other piston manufacturers that make more of a selection, but you'd better make sure you choose a true "nitrous" specific piston because if you trhow a 300 shot of spray towards any piston of lesser quality, you'll probably only be given the opportunity to do that once. After that, you will need some help from friends to pick up all the parts of the motor that have been scattered along the pavement.
There has been some debate over the advantages/disadvantages of a 5.7" rod vs a 6.00" rod, but no one has been able to prove there is any noticable gains of one over the other, at least when it comes to applications like this. Although there are some great aftermarket heads for LT-1 motors, the performance gains from having the stock castings ported have proven to be substantial, especially in a nitrous application. In most cases they will cost you less as well. |
(Post 5108325)
There has been some debate over the advantages/disadvantages of a 5.7" rod vs a 6.00" rod, but no one has been able to prove there is any noticable gains of one over the other, at least when it comes to applications like this. Although there are some great aftermarket heads for LT-1 motors, the performance gains from having the stock castings ported have proven to be substantial, especially in a nitrous application. In most cases they will cost you less as well. A 3.75" crank for a 381-385 works better with no more than a 5.85" rod when running large shots of juice. |
There are other piston manufacturers that make a good nitrous piston as well...maybe with a broader selection. A "custom" piston is wotrh looking into if needed. I'm sure someone else here can give some ideas as well.
Your engine builder or some of the Engine sponsors would be able to help with this question.
I am running a custom Ross piston w/6.0 rods in my 396 |
(Post 5108631)
Diamond Racing Products...
They have a full line of nitrous friendly shelf stock pistons, and can custom make something to fit your application too. |
Originally Posted by Eric@Victory Racing
(Post 5108969)
Ok, so with this http://store.summitracing.com/partde...8&autoview=sku piston, I should be good to go then right? with about a 12:1 compression, double checking before I put these on the list to buy.
EDIT: These look to be the same for $20 cheaper are they? http://www.jegs.com/webapp/wcs/store...0002_696591_-1 |
JE's catalog is on-line.
Rich |
