what injectors do i need
Old Mar 8, 2003 | 11:35 PM
3GLT16speed's Avatar
ok, im tossing around an idea here. i have a lt1, 11:1 compression ratio. if i go with a wet or direct pott system running anywhere from a 100-300 shot, what size injectors would i need. also what would be the best way to go. probally direct port, i would think.
Old Mar 8, 2003 | 11:42 PM
sorry that pott should be port. also you can let me know if im just out of my mind and looking to blow the crap out of my motor. like i said im not decided on doing it yet, just mulling the idea.
Old Mar 9, 2003 | 12:24 AM
LPEdave's Avatar
With a wet or direct port system, you're adding fuel in yourself with the nitrous system, not thru the injectors.
Dave
Old Mar 9, 2003 | 04:52 AM
right, but i wasnt sure if i need to upgrade the injectors anyway. so youre saying the ones i have now will be fine. basically the injectors dont matter, because the nitrous system gets it own fuel. ok.
Old Mar 9, 2003 | 11:37 AM
94z'sson's Avatar
to get the proper size injectors you need to
take rwhp*.5/8 or rwhp*.5/#of cylinders
exp 550rwhp*.5/8cyls you will need 34.375lb/hr injectors which means you will have to get 36lb/hr injectors
Old Mar 9, 2003 | 12:28 PM
LPEdave's Avatar
Originally posted by 94z'sson
to get the proper size injectors you need to ...
That would make sense if he were expecting his injectors to supply 550hp of power, but he's not. He's feeding fuel in through the nitrous system. Unless something's wrong with the current injectors, they should be fine.
Dave
Old Mar 9, 2003 | 09:28 PM
stik6shift98's Avatar
yours will be fine..
Old Mar 10, 2003 | 02:34 AM
the motors gonna be making 450-500hp N/A with 42lb injectors. hopefully at least. my goal for the motor is 500+ horse. i want to do it N/A but if i cant make it, i dont want to have to tear down the whole thing rebuild it for a supercharger. so the squeeze will be my only option.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
