what to do after?
Old Feb 25, 2006 | 01:00 AM
spinish's Avatar
what to do after?
my quetion is what do you do after you get the nitrous kit hooked up. i'll be running 150 shot max. I've never used nitrous before and I don't want to blowup the first time I push the button just because I didn't do somthing I should have.
Old Feb 25, 2006 | 01:10 AM
Bow94z's Avatar
Re: what to do after?
um for starters...
check your fuel pressure
make sure the solenoids are in working order
make sure you pulled out enough timing, and check your window switch..
Old Feb 25, 2006 | 05:00 PM
HeavyChevySS's Avatar
Make sure you install the proper jet(s) !!!
