wet kit question
Old Feb 13, 2003 | 10:13 PM
lt4 fd's Avatar
wet kit question
In a wet kit it draws fuel from the back of the fuel rail correct, a guy I was talking to said that when it starts pumping the nitrous through the solenoid it sucks fuel away from the injectors and leans it out, could this be true or is there no worry of that. Please only knowledgable responses.
Old Feb 13, 2003 | 10:28 PM
jcolez28's Avatar
The fuel pressure oa an LT1 is around 40PSI. This sufficient to run the injectors and the fuel for a wet system.Most N2O fuel cut off switches are around 35 PSI. Is someone trying to convince you dry systems are better?
Old Feb 13, 2003 | 10:46 PM
lt4 fd's Avatar
yup he swears by them but I know you end up paying more for a dry in the end.
Old Feb 14, 2003 | 12:21 AM
jcolez28's Avatar
The exhausted search I did on wet vs. dry told me that the brands with dry werent near as reliable as Nitrous Express. Mainly lock up of the solinoids. And the injectors locking up. Which means new injectors.
Old Feb 14, 2003 | 05:28 AM
94DROPTOPZ28's Avatar
LT1 = wet kit
LS1 = dry kit
I don't know why but I'm sure the LS1 guys could help ya out with that answer
Old Feb 14, 2003 | 06:13 AM
RacinLT1's Avatar
As said above,there is plenty of fuel to go around for feeding a wet system.
If wet systems did "suck fuel away",they wouldnt be sold or as widely used as they are.
Now saying that,if your fuel pump is tired or crapping out,that thing your friend mentioned is possible,but not probable.
Old Feb 14, 2003 | 11:04 AM
stik6shift98's Avatar
Originally posted by 94DROPTOPZ28
LT1 = wet kit
LS1 = dry kit
most ls1s run wet.........
Old Feb 16, 2003 | 10:30 PM
brain's Avatar
Wierd, maybe its a location thing, but most of the guys here run dry kits with an LS1. There are more than a few running in the 11s with just a 150 shot. Anywho, why do most people run wet kits with an LT1. I've always heard that a dry kit is better for fuel injection, as the manifold wasn't designed for gasoline in it.
Jan 23, 2015 01:13 PM
alphaauto
Jan 23, 2015 07:42 AM
Queens94z28
Dec 20, 2014 09:11 PM
ezcheeze15
Aug 26, 2002 01:28 PM
ezcheeze15
Aug 8, 2002 12:27 AM
