Verticle vs Horizontal bottle mounting
I have only seen this discussed *lightly* in the past. I was just curious as to who has their bottles mounted Verticle - and are you seeing any issues with it? If you are please let me know.
I am chasing a N20 "sputtering" problem right now - seems like I cant get all the air out of the line - my bottle is currently Verticle - but it is 100% full.....
Please post your thoughts on Verticle vs Horizontal - the bottle that is
Jeff C - Utah
1994 383 Z28 M6
Bored, Stroked, Splayed, and Sprayed!
www.nvmyz28.com
Utah F-body Assoc.
Jeff C - Utah
1994 383 Z28 M6
www.nvmyz28.com
Utah F-body Assoc.
45 degree is the best way to go. When you have it vertical it settles to the bottom. It is gas but it is still cold and cold air (which has nitrogen and oxygen in it) sinks. Hope this fixes your problem. Also if you dont have a purge kit get one.
2001 Camaro V6 A4
A few mods. :-)
2001 Camaro V6 A4
A few mods. :-)
Either one is just fine. The key is to be sure the siphon tube is pointed to the rear of the car. If the bottle is vertical, the Valve/feedline needs to be pointed to the back of the car (Label Facing the dash).
Angled/Horizontal is better IMO, but vertical should work just fine for ya so long as the bottle is pointed the right way.
Good luck!
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Good luck!
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Now that is an interesting idea....... Thats how the refill stations bottles are mounted - so I suppose it really wouldnt matter.......
Jeff C - Utah
1994 383 Z28 M6
www.nvmyz28.com
Utah F-body Assoc.
Jeff C - Utah
1994 383 Z28 M6
www.nvmyz28.com
Utah F-body Assoc.
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
