Using NOS to offset the thin air in the Mile High City....
Old May 23, 2014 | 05:59 PM
james007moore's Avatar
Lightbulb Using NOS to offset the thin air in the Mile High City....
I am looking for opinions about using NOS (dry) to oxygenate the thin air here in Denver. My car was built, tuned and raced on the east coast near sea level, Now I am living in the mile high city.. I have NOT had my car at the track yet and I will certainly need to make some adjustments to the tune. But since my car is supercharged I was thinking of spraying a calculated amount of dry nitrous via a fogger nozzel plumbed into the intake tube after the super charger and before the intake air temp sensor. I am thinking that this will help by cooling the air from the charger AND also making the air more dense and more oxygen rich.
Old May 23, 2014 | 08:24 PM
Re: Using NOS to offset the thin air in the Mile High City....
Would work, but why not just pulley up the S/C?
Old May 24, 2014 | 10:36 AM
Hey Injuneer how are you doing Sir? I was thinking that if i simply increase the boost that I would still be dealing with the same issue (higher intake air temps and less VE due to the thin air)
Old May 24, 2014 | 12:10 PM
Maybe do both. You lost 20% of the HP due to the elevation. It would seem that spinning the blower faster (depending on the flow curves) would bring the air density back to where it was at sea level. Yes, the fact you are increasing the compression ratio across the S/C may increase the discharge temp. I think you would need to look at the curves, or ask ATI what they recommend. What kind of boost are you seeing in Denver?
Old May 24, 2014 | 01:18 PM
I havent run it yet here in Denver so I am not sure what the boost level is, I have a few other issues to work out before I can really lean on it and see. When you talk about "the curves" I am not sure what you mean, can you explain?
thanks
Old May 24, 2014 | 03:43 PM
The compressor has a set of operating curves (or a "map"), showing flow vs pressure ratio, and the efficiency at each operating point. I believe a centrifugal S/C will flow the same CFM at a given RPM, but the compressed density is going to drop because the density is less at the inlet, due to altitude. So you increase the RPM too increase the flow and the pressure at the outlet to increase air density.
The big problem with compressing air (or any gas) is that there is a temperature increase as part of the process (you can't avoid it), and then an additional temperature increase due to compressor efficiency. You have to keep the compressor operating where it is most efficient, to minimize the air temperature gain.
It gets complex, so a call to ATI may be in order, or post the question on the Forced Induction forum. You are more likely to get someone who can answer your question, with regard to the relative benefit of increasing the blower RPM, vs. adding the N2O. The Forced Induction forum still seems to have a core of hard-core S/C users, willing to help.
This is a Vortech map, but you will find something similar for the procharger.
Old May 24, 2014 | 10:21 PM
Thanks very much for that..I never knew that and it is very GOOD info..
I will read up on that and see what I come up with..
Thanks again, You are always so helpful and knowledgeable (seriously).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
