Turning on Nitrous in mid run?
Old Aug 15, 2011 | 08:59 AM
95zsean's Avatar
I have a NX kit with a Mallory 685 box that I use for my window and to pull time. What I'd like to know is can I turn it on mid way through a 1/4 mile run with all 3 parameters( WOT, over 3000 RPM, and FPSS) already met and it still pull the time and not hurt anything? The reason I ask is that I cant use it in 1st gear the car just spins off the line even with DR. I want to snap the switch on after I shift into 2nd gear, My switches are mounted in the ashtray of the console.
Thanks...
Old Aug 15, 2011 | 01:39 PM
MTL_Z28's Avatar
Re: Turning on Nitrous in mid run?
I'm in the same situation as you. I actually thought the 685 had a feature like that but I was wrong. It looks like we are going to need some kind of progressive nitrous controller or a first gear lockout switch which allows the min. and max. RPM to cycle once before switching on... How bad is it in first gear? Have you tried a smaller shot? You're probably already putting down decent power with the 847 cam. I'm probably gonna put in a 75 shot for now.
I'm looking at this it seems to have what we're looking for:
http://www.dynotunenitrous.com/store...?idproduct=216
Old Aug 15, 2011 | 02:10 PM
95zsean's Avatar
I was told to look at it from a safety point of view. Arm your system like usual but put a switch in series with the FPSS that you can flick easyly after you shift into 2nd. I'm not sure I'm going to have to put some thought into it.
Old Aug 15, 2011 | 10:46 PM
MTL_Z28's Avatar
In that case why not just flick the n2o arm switch after you shift?
Old Aug 16, 2011 | 06:55 AM
95zsean's Avatar
Well, I and the guys at Nitrous Outlet are concerned that with the electronic WOT switch not being powered until you arm the system,that it may not see or recognize the signal and not operate the nitrous????? Have you ever done this?
Old Aug 16, 2011 | 11:09 PM
MTL_Z28's Avatar
Sorry I don't know I have a mechanical WOT switch... but if the guys at nitrous outlet told you they probably know best.
Old Aug 17, 2011 | 07:52 AM
95zsean's Avatar
I was not jumping on you about the switch, I guess I should have stated that I have a electronic WOT switch. I've come up with a plan and am going to try it tonight.... Well see how it works.
Old Aug 17, 2011 | 06:39 PM
MTL_Z28's Avatar
np... I didn't take it that way, I just had no idea you couldn't activate the n2o while already at WOT with an electronic switch. I know for sure it's not a problem with my mechanical switch.
Old Sep 17, 2011 | 01:31 PM
96LT1TX's Avatar
I had nitrous outlet install their progressive controller and I really like it. You can lockout gears or have it open the solenoid over a few seconds to help this problem. For $250 it is a good buy to me.
Old Sep 17, 2011 | 07:07 PM
Button on the shifter...... I used that for a second stage.
http://www.injuneer.com/images/photo.../DCP04165a.jpg
Old Oct 23, 2011 | 10:03 PM
dennis5374's Avatar
I do everytime I spray. I have a w.o.t switch but I spray the car in 2nd everytime. Just hold it too the floor and flip the switch. It works I cut consistent low 11's with it. My 10.8 is spraying on the launch and shifting manually.
Old Oct 28, 2011 | 09:36 PM
MTL_Z28's Avatar
Hey Dennis, when you flick the switch while at WOT, does it take like half a second or so for the nitrous to hit? I was out testing this yesterday and I noticed that when I hit the N2O arm switch after going WOT it would take a split second for it to kick in (not instantaneous) Whereas if I leave the N2O switch on and just nail the throttle, it pretty much kicks in right away and spins the tires...
Old Mar 30, 2012 | 11:10 AM
dennis5374's Avatar
My nitrous goes off as soon as i flick the switch when the pedal is too the floor. I don't notice much of a delay if any at all.
Old Mar 30, 2012 | 11:16 AM
dennis5374's Avatar
Sorry to dig up an old thread lol
Old Apr 11, 2012 | 07:44 AM
95zsean's Avatar
I put a long trucker switch on my HSW ashtray plate so when i shifted into second i can flick it with one finger with my hand on the shifter. It's in series with the ground on the FPSS and there's is no delay when i flick it, works great for me.
alphaauto
Jan 23, 2015 07:42 AM
bandit383lt4
Dec 21, 2014 09:12 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
guionM
14
Jun 19, 2002 08:30 AM
