Trick Flow Elbow/Nozzle
Old Jan 25, 2003 | 05:03 PM
OffspringZ28's Avatar
I really like the trick flow elbow that summit just started carrying. It is like the vortec without the seperator in the middle of it, which i think would be ideal for my shark nozzle. now i am just asking, would it be possible drill the elbow without cracking it or something? i doubt it would break like that but i am looking for second opinions.......thanks
Old Jan 25, 2003 | 06:46 PM
texlurch's Avatar
I haven't seen the elbow you are referring to, but whether it is plastic or aluminum, if you take your time, you shouldn't have any problems drilling it. If you are worried about tapping it for threads, you could just use a "nozzle nut" for the threads. NX sells them, I imagine someone else does also, it is just a two piece threaded insert; you drill an oversize hole and it sandwiches in, then the nozzle screws into it.
Old Jan 26, 2003 | 11:39 AM
Z28ROC's Avatar
You can drill it no problem.
Buy an 1/8" npt tap and whatever size drill bit is recommended for that tap. Find a good spot and go at it.
This is a pic of a vortech. www.z28roc.cz28.com/en1.jpg
Old Jan 26, 2003 | 08:24 PM
awesome! also, which nx system are you running? i really like the 2 nozzles. since i never plan on going above a 100 shot should i stick with my shark nozzle and try to hide it under the elbow??
Old Jan 26, 2003 | 10:09 PM
Z28ROC's Avatar
I'm running a dual stage. That's why I have 2 nozzles.
But in your case, a single stage is fine. It would be easy to tap the nozzle on the underside, for a nice hidden system.
Formula Steve
Sep 19, 2023 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
Cam's maro
Aug 11, 2015 07:45 AM
alphaauto
Jul 26, 2015 04:40 PM
