TR6's????
Old May 15, 2004 | 01:28 PM
TN94Z's Avatar
TR6's????
I am about to do a cam swap, headers, etc..so I have decided that now would be the best time to change the plugs and wires. I plan on spraying th car later on and want to go ahead and get the correct plugs. I have done some searching and have come to the decision to ge the TR6's...my question is, will there be any performance loss when not spraying with these plugs? And am I choosing the correct plugs? Just curious...thanks in advance.
Old May 15, 2004 | 01:45 PM
Fuels94TA's Avatar
Yes those are the right plug for sparying, you can use them as well for average driving condtions. if your using a big shot (150+) gap them at .035.
Vinny
Old May 15, 2004 | 05:28 PM
sniffin94's Avatar
You will definately have a performance loss n/a. I am not knocking these plugs at all. I run them in my car but you can feel a difference off the bottle
Old May 15, 2004 | 06:17 PM
TN94Z's Avatar
Do you think I should wait on the n20 plugs until I get ready to spray? Should I just buy regular plugs now? It will be a while before I spray. I am wanting to get the most out of it NA before I get a power adder. I don't care to wait on the tr6's for a while if it will hurt my performance now.
Old May 16, 2004 | 10:40 AM
sniffin94's Avatar
If you don't mind swapping plugs again then I say wait, you will get more performance with normal plugs. Just under no circumstances should you spray without the colder plugs. Good luck
Old May 16, 2004 | 12:23 PM
TN94Z's Avatar
I'll just wait then...like I said it will be a while before I spray. Thanks for all of the replies.
Old May 16, 2004 | 08:41 PM
roadrage912's Avatar
ummmm.............
you shouldn't see any difference between the stockers and the TR6s when running NA. it's a tighter spark and so that you can burn better. i know lots of ppl running better with TR6s NA than other cars with the same mods and stock heat range and gapped plugs.
it won't hurt your performance one bit. if you want i'll post again after i install my TR6s tomorrow or tuesday.
Old May 17, 2004 | 03:17 PM
BLACKBIRD8200's Avatar
i'm putting tr6 plugs in my car this weekend and i do have nitrous i'm only going to be running a 75 shot so should i gap any differant? and when and if i do go to the 100-125 shot do i have to regap differant?
Old May 17, 2004 | 05:09 PM
sniffin94's Avatar
you will have a n/a performance drop with a tr6 gapped at 35. I have had them in my car for 2 1/2 years
Old May 18, 2004 | 02:42 AM
Xride's Avatar
put them in the same time as the slowmaster?
your the first one to say you have a loss, and one that you can feel.... DAMN must be like 10hp at least then......
I have a real hard time beliving that, and if its true then I would think that your ignition is not up to running N2O
Old May 18, 2004 | 05:56 AM
sniffin94's Avatar
slowmaster??? Idiot. The ignition system is fine. I have a little experience with lt1's and nitrous. 4 of my friends pretty much have the same nx kit and ignition. All of us feel the same way about the plugs. Do we all have ignition problems oh almighty x-ride??
Old May 18, 2004 | 08:10 AM
RacinLT1's Avatar
when i swapped to the TR6 plugs i lost absolutely nothing in n/a times/performance. at the time the car was running high 12's w/bolt on's and eventually went 12.36@109 with those plugs and bolt on's. Also went 11.02@124 while on the bottle with a stock longblock.
no you really wont notice a difference by running those plugs.
Old May 18, 2004 | 09:53 AM
Xride's Avatar
mus be the air there then, cause really, to lose enough power that you can notice it would have to be at least 10 hp, and thats lots.
I've also seen a car change plugs on the dyno, going from stock one with low miles to the TR6 and show NO difference in power.
and then go and run 114 hp more with a 100 shot of NX
there is no reason for a power loss unless you have other problems.
Old Jul 30, 2004 | 06:42 PM
JJJ93z's Avatar
Re: TR6's????
My brother is putting tr6s in his 93z this weekend and he has bolt ons only.but eventually is going to do n20. since they come gapped .035ish out of the box what should he gap them at? .05? thanks
Old Jul 30, 2004 | 07:31 PM
chevyguy3's Avatar
Re: TR6's????
i usually gap them at .038 for most combos
