tpi nitrous
Old Dec 11, 2002 | 10:41 AM
1985camaroz-28's Avatar
tpi nitrous
i want to put a NOS tpi plate system on my engine . it a plate that sits right behind the throttle body.
anyway i also have a aftermarket chip that does advance ignition timing and a 190 thermostat to help prevent detonation so my question. with spray and the advanced timing with it cause engine dedtonation and if it will what should i do?
Old Dec 13, 2002 | 04:49 PM
onefastgta's Avatar
Put your stock chip back in, or turn down your inital timing to 0* and start from there reading the plugs and listening for detonation.
Old Dec 16, 2002 | 07:03 AM
thanks onefastgta
Old Dec 16, 2002 | 05:46 PM
AutoRoc's Avatar
egttrh
For what it's worth, I had GREAT success using an LT1 Wet kit from Nitrous Express on my 305 TPI engine. I plumbed the single "Shark" nozzle IN the MAF sensor behind the hot wire aimed at the engine. I ran the 75 shot jets and my 15.60 running iroc then ran 14.20's with an 8 mph gain I was very impressed.
That same engine now has a Holley 600 Carb and Edel. Intake and SLP headers. I converted my LT1 wet kit to use a Carb. plate from Nitrous Express and used the 100HP jets. It ran 13.30's. Now I have run 2 bottles through the system using the 150hp jets and it screams!! Easily a 12.80 car. Goodluck man. Don't skimp on buying safety items like a Fuel pressure safety switch, colder heat ranged spark plugs, 93+ octane gas, and a full throttle switch. Goodluck and have fun!
Also, I would honestly think that if the engine runs great with the chip, and it does not knock at all...It should be perfectly fine running 2-4 degrees of less total timing and a 100 shot. right? anyone? anyone?
Old Jan 6, 2003 | 06:54 AM
as it is i just want to go faster and honestly like to have buth but i dont want to damage my engine. and if you time the engine down a few degrees wouldent it be slower all the time?
Old Jan 6, 2003 | 06:48 PM
TriPinTaZ's Avatar
Just curious how you " READ" a plug....not liek they write a news article on the radio dispaly when there is knock.
Old Feb 27, 2003 | 08:20 PM
91ReDZ's Avatar
you read a spark plug by its condition white is lean, black is rich,white with little black or grey spots is bad,(detonation)
i had a aftermarket chip in mine so i went to the dealer and bought the stock chip and put it in (60$)
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
