Total Cost of Nitrous
If I were to get a 100-125 shot with everything for it so it is safe and effective, how much am I looking at to spend? Can I install it myself? Is it relatively easy? Is there any sites to lay out the install? Thanks to all.
Well you will be looking at 600+ for a kit. The plus is for all the extras that you want it to run safety equipment. It can be done if you have some knowledge on electrically wiring. If you buy a new kit they do come with instructions on how to install it. If you you have someone install it should be around $150+. Also there are two type of kits out (wet/dry set up) figure on which one will work best for you. You will get many comments about this. As for me, I use a NX system (wet) and love it.
Vinny
Vinny
I'm workin on mine right now, when all is said and done it will prbly run between $800 and $1500, id say like $1000 most likely though, all depends what you want and what you use basically. guys, plz reply to my other post on what i need!! i need help gettin my nitrous stuff!! thanks a lot.
good luck man,
jake
good luck man,
jake
hmm let me see
$575 for the system + $26 bottle bracket + $15 arming switch, so that $616 for everything. ohhh $50 for the install so $666. devil's number. sucks.
ohhhh wait, plus $80 for the window switch. so that's $746.
Umm...how are you guys saying 50-100 dollars for the install? It can't be done in an hour, and considering the going rate is about 65-75 per hour for labor, you're estimates are for about 1.5 hours of work.
nice guys with an experience. he's in my camaro car club.
Originally posted by Wild1
Hey, TMD... did someone say free lunch?!! I'm there too!
Monday?!! Argh.. maybe I can call in a sick day to work
Well, thanks anyways for the offer... fried noodles sound great! One of these days...
