suggested shot size
Old Jul 14, 2005 | 09:53 PM
95firechicken's Avatar
suggested shot size
i am looking at geting a system and was wondering what size shot i would be able to run. details on motor are:
Mike's 1995 trans am
Exterior:
18" OZ racing rims
98 Tail lights
Engine:
355 LT-1 block
Weisco forged pistons 11:1 compression
Eagle forged H-beam conecting rods
Heads:
ported and polished by P.E.P
Ferrea 6000 stainless steel valves ( 1.94 intake, 1.50 exhaust )
LT-4 Hotcam springs, retainers, and locks
1.6 RR
Cam:
LT-4 Hotcam
Duration: Intake 218, Exhaust 228
Lift: Intake .525, Exhaust .525
Drivetrain:
4:10 motive gears
McLeod clutch
Bolt-ons:
BBk Twin 58mm thorttle body
Moroso cold air induction
Pro 5.0 short throw shifter
MSD 6AL ignition
MSD coil
MSD wires
LT-4 Extreme heavy duty timing set
Lingenfelter 3.5" alum. driveshaft
Fuel System:
Walbro 255 in-tank pump
Aeromotive FPR
30 SVO injectors
Suspension:
BMR Adjustable Torque arm
BMR adjustable panhard rod
Lower control arms
BMR Boxed Sub Frame Connectors
Bilstein HD Shocks
Exhaust:
Jet hot long tubes
Jet hot y-pipe with no cat
3" piping
dynomax bullet
Computer:
Tuning done by Jeremy at Fasterproms
Lt4 Knock Module
all arp hardware throughout entire motor. thanks for the help.
Old Jul 15, 2005 | 05:00 PM
HarrisSpeedWorks's Avatar
Re: suggested shot size
With your current fuel set up I'd say right around a ~175 - 200 shot. With a different fuel system (stand alone or larger pump) you could go a bit further. What head gaskets?
Matt
Exterior:
18" OZ racing rims
98 Tail lights
Engine:
355 LT-1 block
Heads:
1.6 RR
Cam:
LT-4 Hotcam
Drivetrain:
4:10 motive gears
McLeod clutch
Bolt-ons:
MSD 6AL ignition
MSD coil
MSD wires
Fuel System:
Aeromotive FPR
30 SVO injectors
Suspension:
Lower control arms
Bilstein HD Shocks
Exhaust:
Jet hot long tubes
3" piping
dynomax bullet
Computer:
Lt4 Knock Module
Old Jul 16, 2005 | 07:15 PM
all gaskets in the motor are fel-pro
Old Jul 17, 2005 | 12:46 PM
CustomSSI's Avatar
Yes a 175 shot should be fine, just make sure everything is up and running good.
Josh
Old Jul 17, 2005 | 03:27 PM
chevy94c's Avatar
Go with 175.
Old Jul 18, 2005 | 01:18 AM
Nitro Dave's Avatar
Looks like a good set up. I woul look into upgrading the fuel system for sure.The single intake will be border line at about 175 maybe a bit more.A dual intake set up will work fine or look into our dedicated fuel systems.However with out splayed caps and with a stock crank 200 would be safe 250 would be border line.I suggest buying a qualitly NX system.If I can help with any tech advice feel free to send me a pm.
Dave
Old Jul 21, 2005 | 05:02 PM
thanks for the advice. how would an in-line 255lph pump help. would that be enough for a 200 shot? thanks
Old Jul 21, 2005 | 07:07 PM
I wouldn't use an inline pump IMO. Inline pumps are just band aids. They can "help" keep the pressure but they can't pump any more then the in tank pump can.
Matt
Old Jul 22, 2005 | 08:49 AM
Nitro Dave's Avatar
I completely agree.I do not suggest inline pumps.
Dave
Old Jul 22, 2005 | 03:12 PM
so would i have to order the dual intank set up from racetronix or could i just add another in mine? if i could just add another one what would i need
Old Jul 22, 2005 | 05:02 PM
Nitro Dave's Avatar
I have seen people do this but I personay have not.I would just order the racetronix system.Let me know if I can help you with one.
Dave
Old Jul 22, 2005 | 09:16 PM
well it looks like it will be sometime then before i join the land of the spray since this is my daily drivcer and i cant afford the downtime on my car at this time. thanks everyone.
HectorM52
Jul 30, 2017 11:46 AM
1775.Z28
N2O Tech
Apr 7, 2015 04:09 PM
drptop70ss
Mar 26, 2015 01:50 AM
cmsmith
Mar 23, 2015 11:45 AM
cyteone
Feb 7, 2015 06:04 PM
