Stand alone Fuel system for NO2
What are the advantages of running a stand alone fuel system from Nitro Dave for my nitrous kit? I know if I start spraying bigger people have said to get it but should I think about it now?
1) Ensures the nitrous system has planty of fuel supply
2) Allows the use of higher octane fuel to reduce detonation
3) Reduces the amounts of race fuel purchased
4) Cheaper than a complete A1000 setup
Cons:
1) Cost over a walbro 255/hotwire
A standard Racetronix (walbro 255 and hotwire) will support 6-650whp
The dedicated will support up to 1200hp.
Every car is different...and I never like to be anywhere near the absolute limit of something as critical as the fuel system
Another big advantage is the ability to tune the fuel pressure as you can use a seperate fuel pressure regulator.
I have a standalone fuel system and the LTCC ignition on my 383. Especially for the bigger shots of nitrous, having the ability to tune both the fuel and the spark will allow you to maximize the power.... and there is no need to go into the PCM for any extra tuning.
The stand alones placed behind the driver's side headlight will only work on an LT1, if you have a ram air hood and the air filter is placed above the radiator. That is what I have with a Nitrous Outlet tank. The quality is absolutely fantastic.
Or you could use the stand alones placed on the battery tray. But then you have the relocate the battery to the hatch area.
Or Nitrous Outlet has tank that mounts in the spare tire well.
Jul 4, 2005 05:00 PM
