Spraying 95 z28
Old Jul 22, 2015 | 04:00 PM
95z28man7's Avatar
Spraying 95 z28
Hey guys this winter I'm tearing down my 95 z28 lt1 and I'm going to build it for spray I'm going to go with all new bottom end 383 stroker kit bigger cam stock heads just bigger valve springs and titanium locks what size cam would be best for spray also the car is auto but I have a powerglide with a break and 3800 stall I'm going to through in the mix
Old Jul 22, 2015 | 04:24 PM
Re: Spraying 95 z28
"Sticky" at top of N2O Tech forum:
https://www.camaroz28.com/forums/n2o...torial-520713/
Old Jul 22, 2015 | 10:20 PM
95z28man7's Avatar
Re: Spraying 95 z28
Will the stock rear end hold together with 33 spline axles and 4.56 gear
Old Aug 16, 2015 | 10:58 AM
streetbad's Avatar
Re: Spraying 95 z28
I believe to install 33 spline axles you would need a bigger rearend.
Fatdog2
Feb 13, 2015 08:19 PM
David Dorris
Jan 17, 2015 08:10 PM
Jan 5, 2015 07:14 PM
tds1213
Nov 27, 2014 12:55 PM
