Spraying a 2 Bolt LT1 Block
Old Jan 18, 2005 | 09:42 PM
  #16
MEAN_SBC's Avatar
Re: Spraying a 2 Bolt LT1 Block
When you're sprayin, you won't have to spike the rpm's as high as off the bottle... Nitrous is all about torque, and this usually takes more effect down low. If the mains are studded, and you don't spin it past 62-6300, you should be safe.
I've got a pal with a 96 Impala SS (LT1) with stock crank, pink rods, and no main studs that runs 14psi, and 125 shot. He's probably made 200 passes with that car with no engine problems. Now his 4L60e tranny is a different story...... He's recently upgraded to a Th400 with a brake.
Old Jan 19, 2005 | 10:09 AM
  #17
Mikey 97Z M6's Avatar
Originally Posted by n20ta2
Stock block bored 30 over stock 2 bolt main sprayed 250 shot and more recently new times with a 300 shot.
The times in your sig are impressive, especially for a 2 bolt block on a 300 hit. Do you run a stand-alone fuel system for the bottle?
Mike
Old Jan 19, 2005 | 10:35 AM
  #18
'68LT1camaro's Avatar
I spin mine to 6,400 with a studded 2-bolt block.
Old Jan 23, 2005 | 05:12 PM
  #19
Thanks for everyones replies. Looks like I'll be using a studded 2 bolt block for this build.
Mike
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
Catmaigne
Dec 25, 2014 12:16 PM
