Spray out of the hole/ don't spray in 1st Q's.
Old Dec 18, 2006 | 06:53 PM
  #16
LT-x7's Avatar
Originally Posted by Javier97Z28
or 4. They're pussies.
RIGHT ON
If it will hook, spray in outa the hole.
If not, get slicks and do it anyway.
I spray 150 outa the hole.
Old Dec 18, 2006 | 09:07 PM
  #17
396D1SS's Avatar
Originally Posted by 69gto96z
I am running a stock 10 bolt with a m6 and 4.10's. I am afraid i may snap the axle spraying out of the hole.
run nitto drags and your tires will break loose before an axle breaks ( only on the street ). Et streets and drags will break an axle on the street though
Old Dec 18, 2006 | 10:18 PM
  #18
speed_demon24's Avatar
That's why you build up the drivetrain before you just start randomly throwing power at it. A car that hooks on the street will be deadly.
Old Dec 19, 2006 | 10:39 PM
  #19
Soccerbum21's Avatar
yeah, but where is the fun in that?
Old Dec 20, 2006 | 03:26 AM
  #20
Z-RATED94's Avatar
Using the money for more go fast parts instead of paying for a flatbed ride home is reason enough for me.
Old Dec 20, 2006 | 10:11 AM
  #21
Jlo's Avatar
Jlo
I typically have the 2-step set to ~4500 to launch (depending on if the track will hold it). Nothin' quite like a 4k+ RPM clutch dump on ET Drags with the nitrous activating when the 2-step disengages. With a new diff 6k luanch is on the way.
Old Dec 20, 2006 | 10:21 PM
  #22
1SlowFormula's Avatar
Originally Posted by LT-x7
RIGHT ON
So you were spraying out of the hole in that video on CPT's website, bottom of the CPT Cars page, you can hear some tire spin, what would it do with stickier tires?
BTW, nice car it was neat watching that video and seeing an RX7 then hear the LT1 roar.
Old Dec 20, 2006 | 10:46 PM
  #23
Bandit 1's Avatar
I spray out of the hole W/ a 5k launch, 28" slick look out
Old Dec 21, 2006 | 12:22 AM
  #24
LT-x7's Avatar
That's me!
There's not really a hole lot of tire spin, it sounds worse than it is, it's more of a real light wheel hop. We shall soon see exactly what it will do with stickier tires. The stock mazda rear ends seem to be holding up quite well.
Old Jan 5, 2007 | 05:59 PM
  #25
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
Hold on just a minute. There is a cam and trans only on that page running a 11.91?!?! What does it take to do that??
David
Old Jan 7, 2007 | 10:04 AM
  #26
which one, I guess I need to go and look, but I thought there were a few fast cam only cars there... Most of those guys are on this board so I am sure you can ask them about their setup...
Old Jan 7, 2007 | 10:09 AM
  #27
OK just went back and looked at the page and the one that i think your refering to is Projectz28, on here but rading that and knowing Brian a little I know he went lower then the 11.91... and Ben Bryant (94 TA TT2S) went 11.92 with a cc305 and more then likely a lot of bolt-on's...
Old Jan 7, 2007 | 10:24 AM
  #28
Ray@NitroDaves's Avatar
We have a customer that ran 11.77 w/bolt-ons, and a 150 shot only.
http://www.nitrousoutlet.com/custome...tails.asp?id=9
Stock internals. 193K miles
Old Jan 7, 2007 | 11:42 AM
  #29
FloydSummerOf68's Avatar
You would be amazed at the times you can get spraying out of the hole rather than waiting.
Old Jan 7, 2007 | 03:58 PM
  #30
dren70's Avatar
this one : BEN BRYANT '94 Trans Am
CAM ONLY LT1 "CC305"
CPT "RACE" 4L60E
11.92 @ 113 MPH
what else does he do to get a cc305 into the 11's?? i didn't think that cam could run 11's. the stall must be way up there. any information would be appreciated.
this one also: BRIAN HARTLEY '96 Z28
STOCK BOTTOM END & HEADS / CC305
CPT "RACE" 4L60E
11.91 @ 114 MPH
*UPDATE* Brian went 11.81 the first time out in '05
with our transmission!
these CPT transmissions must be magic!!
David
