specific headgasket for n20
Old Feb 6, 2008 | 12:47 PM
94TEALz's Avatar
Built a 355 set up for nitrous and just need to know if there is a specific headgasket i should run? a part number would be great. Also was wondering if the sbc arp head studs will work on the lt1? or is there an lt1 specific batch?
Old Feb 6, 2008 | 04:05 PM
rskrause's Avatar
Moderator
Lots of people have leaks using studs on LT1's. I can't think of why the LT1 would differ from any other SBC in that regard, but it has been commonly reported (do a search). How much nitrous do you plan to run? The FelPro 1074 was fine on mine with >20psi + 200hp shot, so it should be fine for you.
Rich
Old Feb 7, 2008 | 03:23 PM
InsuranceGuy's Avatar
I'm also using the FelPro 1074 without any problems but you
might check out the COMETIC head gaskets. They claim
you do not need to o-ring the block/heads even under
high boost w/nitrous applications....prevent water
leaks also.
93Z,383,Vortech,NOS,water/methanol
Old Feb 7, 2008 | 04:24 PM
jerminator96's Avatar
leaks also.
I hear the finish on the block/heads has to be really good for them to seal properly. No necessarily a bad thing, but if you already have everything out of the machine shop.
Old Feb 7, 2008 | 04:49 PM
rskrause's Avatar
Moderator
~1/3 of the time I have seen Cometics used they will seep.
rich
Old Feb 8, 2008 | 07:11 AM
nxfirebird's Avatar
if you get studs the block must be finished honed with a torque plate and studs, studs distort the cylinder walls greatly besause they have a much higher clamping force than bolts.
if you use a Cometic you must have the head and block surfaced just for them, and be very clean when assembled.
to be honest though, as long as everything is square, a standard performance gasket like the 1074 will hold unless your going to spray above 400+ hp.
Old Feb 8, 2008 | 11:26 AM
Ray@NitroDaves's Avatar
I have used both the Cometics and the Fel-pros....no issues from either.
Old Jan 20, 2010 | 09:58 PM
Bersaglieri's Avatar
When do you recommend heads studs over head bolts?
-Dustin-
IndyZman
Oct 22, 2015 02:17 PM
karpetcm
Sep 29, 2015 10:08 AM
KYWes
Sep 26, 2015 08:49 AM
95blkss
Sep 22, 2015 03:18 PM
blaze309
Sep 8, 2015 05:27 PM
